Finally got the new setup in. The rear is almost an inch lower and it’s killing me. What are my options to gain .5-1” in the rear? Add-a-leaf adds to much. So maybe a 5” block? (4” block currently)
airbags?
I tow a heavy boat all summer, and where it sits now is normally how it is when towing. So I’d rather not have it dragging ass towing.
What's your setup here? It looks good.
Edited by All Terrain
Sorry I just saw this, been on vacation for the last ten days. To answer your question, Yes, I'm very happy with the CST kit. I ran there 4" kit on my 2013 Sierra and it was a great kit. The new kit for the K2's is a bracket kit to work with all three of the different uca's that GM used on these trucks. The install is a little more involved since you need to drop the steering rack 4.5" and install a steering extension with the new kit. I did the install myself with help from a friend, took about 14 hours taking our time. Main thing is follow the instructions closely. I went with the CST coilovers in place of using my stock struts and the 4.5" spacer. I wanted the best ride possible. I also decided to do a Deaver mini-pack in the rear in place of the included 3" block.
I just got home from a Florida trip, drove the truck from Michigan to our place there, 2200 mile round trip. I got to say it was a very pleasant ride. I can honestly say the ride is an improvement over the stock ride. It just soaks up the hard jolts over bridge abutments and feels much more planted then the floaty stock ride.
I also decided to go with the Nitto Ridge Grappler in 305/55/20 C range tire, 52 Lbs. over the 10 ply same size version at 64 Lbs. to get a better ride.
You should expect to pay $800.00 - $1000.00 for a shop to install it.
Any other questions I'll be glad to answer.
Thanks so much for the info! Can you tell me more about the Deaver mini-pack? I checked their website but didn’t see anything about the mini pack replacing the blocks? Sorry for my ignorance on this - fairly well versed in level and lift kits, but I’ve never modified the leaf springs etc.
Again, thanks for taking the time to help me out here.
I'll refer you to this link, It gives a better description of  how it works and the install than I could give you. I ordered the Deaver and CST kit from PerformanceLifts . I went with the CST 4.5" coilovers also rather then using the CST spacer with the OEM struts. I did the Stage 1 kit and added the CST street series rear shocks.
http://www.trucktrend.com/how-to/chassis-suspension/1705-lifting-a-2017-silverado-1500-z71-with-cst-and-deaver/
airbags?
That is a great looking truck. What is your setup?
Thanks! Has a few more things to make it perfect in my eyes.
Suspension is a zone 4.5 with billstein 5100 struts set on 3rd setting (total lift 5.75”). Rear is 4” block now, but 5” is on the way.
305/55/20 falken at3w
20x10 -19 Hostile Sprocket
Remove the bottom plastic shield from front bumpere2ded00c13c5813aaf336b36fc276a23.jpg353bc7ea6def16d73b501d8657652ee6.jpg8e2ca9115b66ce022e4067c343bc6af0.jpg
Put it back on lol!!! Looks better on the truck imo
Sent from my VS995 using Tapatalk
Hey guys need some advice
I have a 2018 Crew Cab Silverado that has a leveling kit with 20inch factory rims and I want to make the change to a 4-4.5" lift.  I want to run 17" tires with 35's (I'm old school and like more tire than wheel).  It's mainly a daily driver on the interstate, but goes off onto logging and gas line roads and some sketchy spots during hunting and camping seasons. Which lift should I look at- one is the Fabtech 4 inch Uniball with Coil overs and the other is the CST 4.5" stage 2?  Any input is appreciated. I want it to ride well on road, but be capable off road and not just look good.
Lift has been going well for me since I swapped from RC to BDS.
The only issue I have right now is my rear end is noisy with the BDS leaf springs. You can jump up and down on bumper and it’ll squeak.
I’m going by shop Monday to get it looked at. It’s time for 1500 mile torque post installation.
Overall I’m still happy! Fixing to change wheels to XD.
4.5 inch zone lift with 35x12.50x20 Toyo at2 Extremes. Rims are Fuel Blitz with dark machined tint. No rubbing so far.
Edited by buckeye6
Broken links
What offset are your rims?
Just now, buckeye6 said:
Flip,
The rims are +20.
Thanks , looks awesome,  the +20 kept tires tucked in nicely
Thanks man. I couldn't be more happy with the result.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
