Done!
Looks great! I love that wheel. Are you running spacers in the rear?
Yes sir, 2"ers
4.5” CST 0f04bac07d469d350c8b3fe45e432884.jpg7502349fa1b01f591ae92389640bcad8.jpg
  • Like 4
Are you happy with the CST lift kit? I have a 2017 Silverado that I'm considering it for. If you don't mind me asking, what was the cost of the install?
I paid $1900 for my kit and install, w. 2" spacers and alignment.   Ive had many lifted vehicles, this one definitely rides the most stock-like.   Would do it again in a second.
sorry, I cant find which lift you are running.  I see the pic of your red truck (nice) but couldnt find the lift brand and specs.
I believe he's running a zone 4.5 with 35s.
Yep
Thank you   On a 1/2 ton?
14 hours ago, big papa said:
Yep
Edited by EZTundra77
This thread is pretty big and it's hard to search.. I know it's probably been posted. But who has the McGaughy's 7-9" lift on 35x12.50 with 22x12's? Looking to set mine at 7-8" for time being.
Here's my 17 Z71 6.2 with a 7" Readylift, 20×10 -19 Hostile Rage H113 and 35x12.50 Nitto Ridge grapplers. I'm going to make a separate post that gives more detail on the lift install. I'll add a link after I make the post.f2451584afa982812095522108b204a6.jpg
Sorry I just saw this, been on vacation for the last ten days. To answer your question, Yes, I'm very happy with the CST kit. I ran there 4" kit on my 2013 Sierra and it was a great kit. The new kit for the K2's is a bracket kit to work with all three of the different uca's that GM used on these trucks. The install is a little more involved since you need to drop the steering rack 4.5" and install a steering extension with the new kit. I did the install myself with help from a friend, took about 14 hours taking our time. Main thing is follow the instructions closely. I went with the CST coilovers in place of using my stock struts and the 4.5" spacer. I wanted the best ride possible. I also decided to do a Deaver mini-pack in the rear in place of the included 3" block.
I just got home from a Florida trip, drove the truck from Michigan to our place there, 2200 mile round trip. I got to say it was a very pleasant ride. I can honestly say the ride is an improvement over the stock ride. It just soaks up the hard jolts over bridge abutments and feels much more planted then the floaty stock ride.
I also decided to go with the Nitto Ridge Grappler in 305/55/20 C range tire, 52 Lbs. over the 10 ply same size version at 64 Lbs. to get a better ride.
You should expect to pay $800.00 - $1000.00 for a shop to install it.
Any other questions I'll be glad to answer.
Here's my post and review of the lift.
https://r.tapatalk.com/shareLink?url=https://www.gm-trucks.com/forums/topic/221733-review-of-readylift-7-lift-on-my-2017-silverado/&share_tid=221733&share_fid=33003&share_type=t
Sent from my SM-G975U using Tapatalk
Finally got the new setup in. The rear is almost an inch lower and it’s killing me. What are my options to gain .5-1” in the rear? Add-a-leaf adds to much. So maybe a 5” block? (4” block currently)
airbags?
I tow a heavy boat all summer, and where it sits now is normally how it is when towing. So I’d rather not have it dragging ass towing.
airbags?
A 5" block will probably work for you. My new setup is also 1" lower in the rear. I already have 6" blocks so I'm going with an add a leaf. Every review I've read and talked to a couple shops says the add a leaf will settle at 1.5" of lift. I'm good with 1/2" of rake.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
