On ‎1‎/‎29‎/‎2019 at 12:08 AM, SuperAllTerrain said:
I have a 2014 GMC Sierra All Terrain did the 7-9 inch Mcgaughys lift kit I had it set at 8 inches high with the rear traction bars and upper control arms all by Mcgaughys, wheels are 20x10 -12 offset Fuel Mavericks and tires are 35/12.50/r20 Toyo open country R/T also have the amp research power steps, backflip revolver bed cover, recon tail lights and recon 3rd light brake, pro comp 40 inch light bar custom OEM headlights with the switch back led boards and demon lights, recon bullet antenna, Morimoto fog lamps, Borla s-type exhaust, k&n air intake black gmc logos z71 grille emblem, window visors and last the weather tech oem gmc floor mats. tires are quiet and drive smooth tires very new coil over in the future ef867c85cb3c9c7f89211706d3e8e4a8.jpg979d4f1191d62ecbff02aeb27b4fe368.jpgfcd8faa58e8a718cccc0ab410f381bb9.jpg79a418f19c9ec50214f730dd7479ea33.jpg6638dd8f1c118caf14fc95ca76548cb3.jpg
Sent from my iPhone using Tapatalkd4d830f8c44f3775f977622ae5d50a83.jpg6c412cad207a8a790de2256d2c49b743.jpg3e06f673dd283c2355b4819ded2fd9bd.jpgfc158d56dc8c1f5f72f6202538bd203a.jpge4d88cfd572693f34ea96a53df8f75f9.jpg30ceb8e22305955618f04556451baab8.jpg
Lookin awesome!  Are you sure your wheels aren't 20x10 -24?  The lip looks like that versus -12.
On 2/4/2019 at 1:38 PM, buckeye6 said:
Nice!! We have almost same truck.
 Which side steps are those? I've always liked the look without them....  but everyone has issue getting in and out with the lift and I noticed my seat is showing g signs of wear now..     but cant decide which ones I like yet....  your pic helps to seem them on the same truck
FlipZ71,
The steps are the Havoc HS2 steps. They were out of stock for the 1500s but the 2500/3500 model works for our trucks, too. I prefer the look without them, as well, but my wife makes use of them. They work well for getting in the truck but it’s a bit of an adjustment getting out and using them, coming from the full piece steps from GM. I’ve only had them for 2 weeks, so time will tell.
Yea I’m sure they are -12 looking to up grade to 22x12 -44 would like a wider look or just 20x12 for now
Your stance now looks really good!  That's why I thought they might have been 20x10 -24, maybe its just the photos.
Finally got a decent day to clean up the truck a little bit. Here's my 4.5" Zone with 33x12.50x20 Toyo R/T and Hostile Sprockets.
Pretty happy with how it turned out. I will be ordering 35x12.50x20 Toyo A/T2 Extremes and Fuel Blitz wheels as a summer setup.
Looks GREAT!
Sent from above
  • Thanks 1
BUCKEYE what is your wheel offset if you dong mind me asking.
I am excited!
Truck was dropped off today to replace the RC 6” with a BDS 6”, full coilovers with reservoirs, and BDS rear leaf springs.
I pick it back up next Monday because I have to go out of town.
SO EXCITED!!
3 minutes ago, geswek said:
I am excited!
SO EXCITED!!
Sweet!!! You will love the coilovers...
Lstarr, they are +10.
nice I like the stance.  I have a plus 18 and am wanting a little bit of a stance like this.  I don't think it would look much different than yours being its a plus 10.  Also being we have the same truck what type of gas mileage are you getting with those 33s and lift?  Thanks for replying bud.
Yeah yours should be very similar to mine with the offset that you have. I seem to getting around 14-15 mpg now with the lift, with lots of stop-and-go and hills where I live. I felt like it was a little better before the lift (maybe 1-2 mpg), but it may just be in my head. Either way, it was well worth it, in my opinion.
Yeah that's pretty damn good and well worth it indeed.  I am getting my truck lifted in a few weeks due to only having the leveling kit now.  And I am so torn between your 4.5 setup and the 6.5 with 35s.  I know it will take a huge hit with the 6.5 and 35s.  Im driving myself nut trying to decide what setup to go with.  Even thought of the 305/55/20 so its 12 wide and just a hair taller than a 33.  im back and forth!  Did you consider the 6.5 at any point and do you see yourself going bigger in the future?  Again thank you for the replies!
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,270 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
