I think everyone here is getting way off track here.
The question I asked was.....Did any one else have the same problem,....was getting approx 22 mpg
and then took it in for a recall and NOW get's 14 mpg.
ANYWAY
GM saw the post and is going to look into it deeper.,I will post what they come up with.
(P.S. I brought this to GM's attention before and they blew me off!!!!)
Hello schultzy1957,
I have located your previous case. Have you been to your dealership since you had the recall completed? I would be happy to set this up for you. Just send up a PM if this is something you would like us to help you set up.
Jonathan A.
GM Customer Care
Hello,
I am the proud owner of a brand new 2014 Chevy Silverado! I just brought my truck home for the first time Friday night (6 Nov). when I drove it of the lot my truck had only 3 miles on the odometer. Once filled up with fuel the range indicated that I could drive 200 miles...I chalked it up to being brand new and figured it was because it is the first full gas tank it has ever had. However, I am already down between the Half and quarter tank marks and have driven only 140 miles! What's really going on? Did anybody have this experience with their first tank of gas? Does it get better? I have the 5.3L V8 ECOTEC3 and the 3.08 Ratio. My window sticker says I should get 470 miles on a full tank...does anybody else get this? Thank you everybody in advance! I look forward to your feed back!
Hello,
Gas mileage should increase dramatically by 500-1000 miles. It'll probably continue to increase slightly up until 5,000 miles.
The first few tanks are in no way representative of what you'll be getting after the engine breaks in and the computer has calibrated the engine, transmission, etc.
Wandern, thanks for the reply! I hope you are right. I'll keep folks posted with my experience. Maybe I will start a new thread about it and keep a log for people to track with me. This is the first new vehicle I ever bought!
Hello,
That's pretty bizarre. From day 1 I've been getting 450-500 or more miles per tank, and I'm at 12,000 miles now. Do you spend a lot of time idling or warming up using remote start? Even with nothing but around town I would expect 16x25=400 miles per tank.
Update:
It is now 4:30 PM Monday, My e-mail from GM last week said I would hear from my dealership and that GM would get back to me on Friday.....YES 3 days ago...Guess what ???? That Never Happened. And Neither did a call come from the dealership.
Got an E-mail from GM ( this morning) asking ALL the same questions from a week ago!!!!!!! (Different person)
Any Body have a NAME or a PHONE ext. number for someone at GM who MIGHT REALLY CARE ????
Cause I am thinking they just put it here on this forum to look like they do.
Dealership today told me I have to give it at least 3500 to 5000 miles before I see true gas mileage. They said it's not broke in...
I was told the same thing and now that I'm around 4000 miles I'm seeing better fuel milage. I average about 19 mpg now with a 50/50 city and highway. Can't complain. Mine also came with the update so that might affect it.
It does take several thousand miles for the engine to break in completely, until then the mileage will be done some.
Well I fueled up today! 283 miles to the tank. And i was sweating bullets because I thought I wasn't going to make it to the gas station! The truck took 21 gallons. So some quick math tells me I was getting between 14 and 15 miles to the gallon...I think. But what I'm confused about now is why do I have a 21 gallon tank and not 26 gallon tank? My owners manual says it should have 26 gallon tank. It does not even show 21 gallon as an option.
That kinda sucks. Was your low fuel light on? Mine comes on with about 2-3 gallons left, so my fill ups are always about 24 gallons, 450-500 miles to a tank. I've been getting this mileage from day one.
im averaging 16... no where near the guidlines lol
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
