I ran mine over the axle then dumped them by the spare tire. I would recommend doing that the same. My buddy dumps his right after the muffler and its pretty loud.
Did you notice any power lose when dumping it
Edited by Bigluke
I personoally only use Magnaflow, I have the 5x11x22 in mine and it sounds great, but it also was the only muffler that Magnaflow offers that has 3.5" inlet/outlet in a center/offset configuration.
Tjay , would it be possible to get a sound clip of your truck at startup and idle and rev? Thanks alot
Did I miss it or what's the point of this flapper anyways?
To quiet the exhaust note when at lower RPMs... basically the opposite of what most on this forum want. ha
Yep... it's supposed to reduce noise/drone during regular driving and V4 mode.
Dynomax uses them... notice how smooth & well-designed the Dynomax valve is v/s GM's design. http://www.dynomax.com/mufflers/dynomax-vt-mufflers
I wonder what that little return spring is made of on the DynoMax... I just cant see it holding up to a couple thousand heat cycles, but I'm sure DynoMax Engineers have thought of that and made the spring from some tung-stain-tanium alloy, only mined in the remote regions of of SW Kansas.
Edited by iCryWheniGoPoop
Did the muffler delete at about 700 miles and by a thousand that damn valve started rattling like crazy during cruising speeds. Gonna go with a Magnaflow with dual outlet and regular chrome tips out the rear. Screw that piece of crap valve.
I deleted the valve and it sounds much better!!
Thats stock exhaust? Sounds great!
Okay so I installed my new muffler went with a flowmaster 40 series just single in single out and had the resonator removed it sounds good but there a weird noise almost like a exhaust leak but check all the welds there good. Could this be the stupid valve behind the muffler and should I remove it
Yes, stock 6.2L exhaust with the adaptive valve removed.
I cant get it to play on Ipad can you put it on youtube or something?
