Denali Grille
Looks good. How hard was the install?
I went with the Denali grill on my 2011 and think I'm going to go with the All Terrain black grill this time. Do you by chance happen to know the price or part number for that grill?
Install is easy, if you're familiar/comfortable with removing parts from new vehicle. Look at the first two diagrams posted here:
http://www.gm-trucks.com/forums/topic/153324-2014-parts-diagrams/
I think this is it, but definitely call and verify the part number with your local dealer before ordering anything online!
http://www.gmpartsonline.net/parts/index.cfm?searchText=22972202&make=GMC&action=oePartSearch&siteid=215055
  • Replies 43
  • 4 months later...
Well, technically the Topic Title should read First Member with a Denali Grille! :thumbs:
(truck's dirty but the grille is clean)
HAVE YOU NOTICED ANY NEGATIVES FROM REMOVING THE AIR DAM? AND ARE YOU PLEASED WITH THE CHOICE OF MUFFLERS?
No negatives. Yes very pleased.
I like the Denali grill but I have been looking for bottom piece where the license plate is. Does anyone have the part# for that yet?
Call your dealer's parts dept and they can tell you the #. That's what I do when I'm looking for something.
I really like this look. Did you have to get a new GMC emblem?
The Denali grille came with the GMC emblem already installed (but if you ordered a different grille without, it's easy to remove & swap)
Mmmm, all this talk about a "grill" from everybody, is making me want to go BBQ.
Nice grille Moto! It really looks great on your truck.
Damn you people in warm climates! :nonod:
Awesome truck OP... I want to get a level and remove the air damn on mine as well. Which leveling kit did you use? Did those mods hurt the mileage at all? What size tires?
2" Rough Country Level with 33" Cooper Zeon LTZ tires (275/60R20). On average, leveling kit & removing air dam will cost you 2 MPG @ 75 MPH.
There's a bunch of 2014 lift & leveling topics in the Suspension section of forum (http://www.gm-trucks.com/forums/forum/46-transmission-suspension-transfer-case-axles/) if you're curious about other options.
Yeah I'm still debating which kit I want to use.... Sorry just noticed you answer all my questions in your signature.. My bad. How is the BB tune on your ride? Is it still only for the engine? Or can he do the tranny now too? I messaged Justin about it, mainly asking if GM can see it if I flash to stock.. But already have the efi live scanner from my last truck. Itching to get a tune myself.
Awesome truck and awesome mods. Making me anxious to get mine personalized a bit.
Are you guys planning on grating large blocks of cheese with those grills?? lol
Used to make cheese sticks actually haha
Sent while drinkin' a cold one...
    C. Hart
    C. Hart
  • Who's Online   3 Members, 0 Anonymous, 500 Guests (See full list)
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
