I was excited about it because the reviews talk about how smooth of a ride they give compared to stock. I sometimes regret getting the Z71 over the standard 4x4 because of the stiff suspension in it. Potholes and speed bumps will jar your bones!
Oh, and do you have to get a new alignment with the quicklifts? I assume you would but not sure.
Yes you will need an alignment. They will lift the front end 2".
I had the Rancho Quick lift level kit on my Denali. The ride was better than stock but I took them off to put a 4" Fabtech lift instead. post-130662-0-77893300-1412736103_thumb.jpgpost-130662-0-27520500-1412736122_thumb.jpgpost-130662-0-56371100-1412736137_thumb.jpg
I had the Rancho Quick lift level kit on my Denali. The ride was better than stock but I took them off to put a 4" Fabtech lift instead. attachicon.gifIMG_20141007_214103.jpgattachicon.gifIMG_20141007_214034.jpgattachicon.gifIMG_20141006_120345.jpg
Did you add wheel spacers?
Yes 2" Spacers for a better look IMO.
Looks great! Do you have any pics looking straight at the front and/or the back? I have. 5" but thinking I want to do more. Lol.
Ok guys I have read the entire post haven't seen an answer to the set up I am getting ready to order. Wanted to get some input. Looking at a XD Misfit +0 offset. Will a 305/55/20 fit with no rubbing? Or do I need to go with a 295/55/20. Looking at putting fender flares on so wanted a tire that wasn't tucked underneath.
Truck Set Up
2014 GMC All Terrain (Z71)
2.5" Rough Country Lift
I think they pop out just enough.
Edited by 14GMC14
I installed the rancho quik lifts, so far I am very happy with them, the ride is better.
What setting did you keep them on when you had them? These look pretty cool!
Truck Set Up
Shouldn't rub with +0 Offset. My +20 offset rubs very slightly at full lock because they set in 3/4" and hit the sway bar.
What tire are you running? On your tag you show a 305/50/20. Im looking at a 305/55/20 which is a bit taller. May try a 295/55/20
Yes a 305/50/20 mine is a Toyo AT II 32" tall vs 305/55/20 is 33" tall I have plenty of room for a taller tire but the width on a +20 offset is the issue. a +1 would move the rim out 3/4" and I'd have no rubbing. There are other guys running 305/55R20 MT's on a 0 or +1 offset with 2" level and no rubbing on this forum.
The Rancho website says that these 2 inch QuickLifts are not compatible with the Z71 package. Does your Denali have the Z71 option? Any idea why? I do have the aluminum LCA's.
On the Rancho website it says they have 9 position adjustability. Is this for stiffness of ride or for lift height? (Or maybe for both if they are linked to each other).
I really want a 1.5" lift, but this does have appeal.
I wonder if they claim they are not Z71 compatible because it is not as stiff as the Z71 which is part of the point of the Z71.
    RichardRS
    RichardRS
  • Who's Online   0 Members, 0 Anonymous, 490 Guests (See full list)
