I just got the Rough Country 2" level and the Bilstein adjustable shocks put on the front and a 2' block in the rear. I had them adjust the shocks just to the first level. A total of 2.75" in the front and .75" in the rear. I put 305/65r18 BF Goodrich KOs. No rubbing at all, they measure about 33.7" tall. I couldn't be happier with how my truck turned out.
Got any pics? This is what I was going to do but held of because I wasn't sure how the ride would be.
Sorry about the crappy cell pics and how dirty the truck is. First nice day here in the great white north. Will take some more pics tomorrow when I get my new rim and tire setup on.
Has anyone else noticed a mark where their spindles and lower control arm are coming in contact after leveling? I have the mark on both sides on the front side of the lower control arm.
That does not look good. What size and type of lift did you have done?
I have a 2" rancho quicklift. I have a feeling its just because I have yet to get it aligned and the toe in is causing it.
Help me out, I can't make up my mind on which tires to get.
I have factory 20x9 Black Chrome Sierra wheels on my Silverado. They came with 275/55 Conti LX20 Eco tires. I want to put an AT tire on, but I can't make up my mind.
I have no plans to lift, but I don't mind doing a level if I have to. I would prefer to stay stock height though.
Should I just get a AT Tire in 275/55, or do you think I'll be fairly safe with 305/50?
RC 2 inch spacer and bilstein at +.75 in front and RC 2 inch block in the rear and bilstein 5100. Love the set up. Rides awesome. 100 times better then stock ranchos.
How are your UCAs? Are they maxed out? I'm going to run my Bilsteins at 1.85" for the next decade or so until i either A.) Go with a coilover setup, new UCAs equating to a 3" lift. or B.) buy a long travel suspension kit and be done with it.
Yes, you need an alignment. I popped my Rancho Quicklifts in and went to Firestone for the lifetime alignment. The guy at Firestone said my alignment was way off due to the Quicklifts.
Could you post a couple more pics? That stance looks perfect. What's you wheel and tire combo?
20x10 motto metal wheels with a -14 offset and 33x12.5 open country mt's plus 2" hubcentric wheel spacers all around
Edited by rubens megatron
What leveling kit are you running?
Finally got mine done. 2.5" RC level with 18" Fuel Mavericks wrapped in 285/65-18 Nitto Trail Grapplers
    KirbyCo
    KirbyCo
  • Who's Online   1 Member, 0 Anonymous, 801 Guests (See full list)
