just bought my first real truck.. 2015 GMC Sierra 1500 SLT z71 4x4 in summit white, loaded out with everything including the 22" SYE chrome wheels. Absolutely love it! Doing a linex bedliner tomorow and this weekend Im going to install the RC 2.5" leveling kit but I think Ill leave the stock rear block in first to see how that looks.. I think the 2.5" front w/ stock rear block should be level or maybe the rear .5" above the rear on mine..
Will update with pics!
I actually ordered the rc 2" front leveling kit first, and then ordered the .5" extra for the front and the 2" rear block, if I needed either after first trying the 2"...
well I got the 2" front kit today.. the front spacers only measure 1"...????
Got my RC 2.5" leveling kit in the mail today and plan to have it put on tomorow. Before and after pics with measurements will be included.
Anyone have some tips on doing this job alone in a driveway?
They give two inches of lift though. And go between the lower control arm and strut.
It def helps to have an extra set of hands for sure, the hardest nut for sure is the upper ball joint since u can only get a wrench on it and not a socket, a cheater bar helps. Also from personal experience i wouldn't take anything off all the way just loosen everything it tells u to and its a lot easier, and yes go get it aligned afterwards to make sure the tie rods and everything are correct and tight (mine was off on one side for whatever reason).
do your plastic c block spacers for the front measure to 2"?
Due to the way the suspension geometry works, a spacer provides 2 times the lift as thickness. So a 1 inch thick spacer will give 2 inches of total lift. It's roughly a 2:1 ratio.
Didn't actually measure it but looking at the part it appears to be 1". From my understanding there is a part measement to lift ratio.
Thanks for the heads up. hopefully all goes well and I have pics for yall tomorow.
My biggest tip would be to loosen the sway bar on both sides, this will give the you a little more flex on the suspension allowing the lower block to be installed easier.just my 2 cents.
A set of ratcheting box end wrenches are worth their weight in gold for installing the lift in my opinion. I did the lift by myself in my driveway and it took me about 2.5-3 hours. Extra set of hands definitely helps but it is very doable with by yourself. Good luck.
PUT my RC 2.5" level on today. Only did the front and left the rear alone.
Well from beginning measurement to the eding measurement took about 4 hours roughly. Had some trouble finding the right tools in the jungle of a garage haha.
beginning measurement was
front 36 1/2"
Rear 39"
Ending measurements
Front 39"
rear 39"
To be clear this is a chevy 1500 crew cab 4x4 standard bed On stock 18" wheels and P 265/65 tires
Now to figure out how to download pictures from my phone haha
front 36 1/2"
Rear 39"
Ending measurements
Front 39"
rear 39"
Here's some ways to post pictures:
http://www.gm-trucks.com/forums/topic/167827-how-to-upload-photos-to-the-forum/
Post em up :cheers:
    tararebecca
    tararebecca
  • Who's Online   3 Members, 0 Anonymous, 669 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
