Decided on doing the RC 2.5" level since wife has concerns about full size (6-7") lift with kids in future. Planning on mid to aggressive AT tires in Size of 275/65r20's or 285/60r20's with stock all terrain wheels. Just need to find reviews and pics of both.
Based on this level and tire size should I upgrade to fox shocks in The back or just stay with stock?
2015 Z71 Silverado 5.3 V8
Bilstein 5100 adjustable strut 2" Level Front
Bilstein 5100 Rear Shocks
Toyo Open Country AT2 275/65/20
MHT Fuel Nutz 20x9 wheels
Magnaflow 18" Dual Exhaust
Zero Rub
Couple of pics including a Before and After
I'm going this route with my factory rims, what settins do you have the shocks at?
I have them on the highest setting. Geometry didn't change much at all...ride is VERY smooth with the 5100's all the way around and I feel like it has a good stance. Looks identical next to a friends 2014 with a RC 2.5 level but a much smoother ride.
Edited by second2none
Just did the Pro Comp level 2.25 inches I believe it is and larger blocks in the rear. Ordered Toyo Open Country AT2 305/55/20 with Fuel Maverick +1 offset. Haven't seen anyone with this exact setup on here, but since I'm new to all this figured I would get some of y'all's expert help. Dealer said he thought there would be minimal rubbing if at all, do you guys think this is true? And how far do you think this setup will stick out past fender wells? I have 15 Silverado 1500 LTZ.
I'd say that is definitely going to rub the front inner fender where the mudflap is. I had a 2.25 level with 295/55/20 with 18 offset and had about half an inch clearance while turning
Rc leveling kit, 285/70/17 Mastercraft Courser mxt tires on rockstar II's, westin contour bull bar, iron cross step bars without steps on. Sorry its muddy.
How do you like the level so far? I was set on RC 2.5" but my shop recommended procomp. Said they'd do whichever I wanted though.
For those of you that have already installed a leveling kit... Which did you go with and why? Do the new aluminum suspension parts impact the install? I hope to get one on my truck in the next couple weeks but want some insights first.
I installed a rough country 2 1/2" front and 2" blocks in rear for an extra 1" in back. Looks awesome but i will warn you, it's not that smooth factory ride that it once was. Rides a little rougher. I bought some rancho xl9000 adjustable shocks for rear, and that helped a lot. Still rides nice but the front is a little stiff. I also changed tires to Cooper AT/3 6 ply so thats a little stiffer that the factory goodyears. Ill post some pics here shortly
Zero Rub
Looks great man! What offset are the wheels? It looks like Fuel wheels come in 2 different offset options and I'm curious which one you chose.
Thanks
Josh
Thanks
Josh
Curious on the offset as well?
I have had my 2" level on for about 8 months now and the left front side is starting to click when I turn the wheel. Is this CV joints gone bad?
Is everyone getting an alignment with a 2 inch level or is it fine to go without.I've seen mixed reviews but I'm just not 100% sure.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 443 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
