2 inch RC level with 275/65/20 GY duratracs. Haven't noticed any rub, looks close to the carpet liner only.
I know this post is a month old already but I just came across it and I was actually thinking of doing this set up with my truck. How high does your truck sit now? Also, how off is your speedometer?
I never measured the height of the truck but can do so later. The speedometer is off according to a tire size comparison website but never actually checked against gps. The calculator says at 40mph the truck is really going 42.8 mph. The faster you go the greater it is off.. At 70 the truck is really going 74.
I like the duratracs and am considering. Has your mileage been affected much by the level and tire swap? You're the first I've seen with the exact setup and size I want.
I like the duratracs and am considering. Has your mileage been affected much by the level and tire swap? You're the first I've seen with the exact setup and size I want.[/quote
Not gonna lie , I haven't calculated the gas mileage. You can't go off the DIC anymore cause I've traveled further than it is calculating. I don't drive too far for work so even if it did suffer It wouldn't bother me much.
I have a 2015 Gmc Sierra 1500 All-Terrain and a 2.5" RC level kit on the front only. What is the biggest tire I can run? I'm sure it has been answered, but this thread is ridiculously long. I also have 20inch A/T painted rims. I was hoping for 275/65/20 or 295/60/20 but who knows. Thanks
Did you retighten the ones in the middle of the sway-bar, as well as all the ones connected with the Bilstein install? They always say to recheck after some mileage.
Also, just a question... did you get your alignment, yet? Could they have left something loose?
Im going to drop it off at the shop tomorrow and theyll take it apart again. Once they figure out whats wrong theyll do an alignment.
Does this bushing look right to you? (pic in attachment)
Edited by derekc89
Traded my silver 2014 with 2.5rc and 295/60/20 for a red 2015. 2.5rc and 285/65/20 bfg ko2
I love your set up on the red truck. Are you close to rubbing? I am leaning towards a proComp 2.25" level with these tires. I may go with 2.5" level if you say you are close to rubbing. I have the same rims as you. I found the ko2 285/65/r20 tires for $1270 delivered which seems reasonable. I guess I could add a body lift if these tires end up rubbing. Thanks for your time!
Another general question....
Are there typically some pretty good deals to be had on tires on Black Friday?
I have not had them rub but I think they are really close. I only have 1000 miles on them and zero off road miles. I am very happy with them.
Pretty much exactly what mine look like.
I would like to raise the front of my 2015 GMC Sierra 4x4 SLE. But I'm not sure to install a 1.5"level kit from ready lift or install shock Bilstein 5100 height adjustable. Please help me to make a decision.
Mike
2015 GMC Sierra 1500, 4x4, SLE
I used the Bilstein 5100's on my truck and really like them. I know most ppl on here go with RC 2 OR 2.5" or similar route but, it's just personal preference. I've also heard that the Bilstein's are backordered almost everywhere.
RC 2.5 in front, 1.75 block in rear
Where did you get the 1.75" rear block? The RC website lists the block in the 2.5" kit as a 2" rear block. Does the kit actually contain a 1.75" or did you use a different block?
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 479 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
