Where did you get the 1.75" rear block? The RC website lists the block in the 2.5" kit as a 2" rear block. Does the kit actually contain a 1.75" or did you use a different block?
I had the RC 3.5 kit installed for a little while but didnt like the ride quality and it caused some steering issues. So i took it out of the front, but left the back block in. I thought it was 1.75" over stock but cant remember for sure. It does give the truck a nice little rake though. planning on putting in a zone 1.5 body lift to get it where i want.
It looks great. Don't suppose you have a pic directly at the side while it's sitting on level ground?
thanks, if its not too dark after work i will get a pic
Man that looks good. It's darn close to level with just a slight rake. You still rocking the factory tires? What size are they?
thanks! no where close to completion but its a start. waiting to wear out the factory tires (275/55r20) and then putting on toyo AT's 295/55R20
Just got my new truck, lifted it and put tires on right away.
GMC Sierra 2015 Elevation Edition
Lift:
Rough Country 2.5 inch level with RC rear block
Tires:
275/65/20 Toyo Open Country C/T (34.3")
Very happy with this choice was going to go with the BFG KO2 but they are on back order till the end of the month. The Toyo's are great a bit louder then KO2 but ride good.
Pics:
When I got it:
After lift and tires:
With air deflector on
No air deflector:
Will get better pics up tomorrow
Lift:
Tires:
Pics:
When I got it:
No air deflector:
Got specs on the Ford my friend wants a setup like that
More pics:
First sweet truck and digging the GTR!
Second, whats the measurements of the fenders to the ground on the front and back?
