$1100 for two side mirrors?? WTF????
ZK686
I have a 2008 Yukon Denali, it has 63,000 miles. While it's out of it's manufacturer warranty, I would still expect NOT to have to spend over $1000 on side mirrors!!
My side mirrors stopped adjusting, and then they stopped folding in.
I took it to GMC and they said it would cost $1100 to repace both side mirrors!!
Each kit cost $400, plus another $300 in labor.
WTF? Is that how much these power side mirrors cost??
This is crazy.
They are easy to replace. I did them in our Tahoe and truck (switched to turn signal mirrors). I got it down to about 20 mins each :)
Find some on ebay or similar site and replace yourself. Enjoy the extra $$$
While I can understand wanting options to work correctly, but, after you set the mirror when you first got the truck, have you ever adjusted it again? I think you will find most trucks do not have power folding either. Were it me, I wouldn't bother replacing them now and just wait for some used to come up for sale here. Generally you will find them for a bit over half the price of just one when they are used.
I would definitely find a way to replace them myself. It's not hard at all. No way I'd pay $300.
I wouldn't pay $400 for a mirror if my life depended on it.
I'd hit the local boneyard, or eBay - plenty of these late model trucks getting wrapped around trees and other cars all over the country.
Local yard wants $350 each for DL3's
Sent from my Samsung Galaxy S4 using Tapatalk 4
Wow ... WTF is right!
Maybe some wrecks will show up on eBay ...
Apparently, since it's a Denali the mirrors are fully loaded. You can't find them at a junkyard or boneyard because no one is turning in GMC vehicles with these types of side mirrors, I've already looked.
They have the light up turn signal, mud lights on the bottom, and programmable adjustments.
I found some here, but not sure if I should chance it:
Denali
Any thoughts about Dorman's parts?
it has no memory or auto-dim according to Dorman's site
Local yard wants $350 each for DL3's Sent from my Samsung Galaxy S4 using Tapatalk 4
Wreckers used to charge 50% of new list last time I went. Even $200 a piece hurts.
Ill spend up to 250 each on them. I max at 500 for the pair
Denali
Just as good as oe in my opinion. I replaced pass side twice. std remote control, not heated or auto folding. Paid about $35 each took 15 min to r&r.
I had to replace one tow mirror on my truck because a bus hit it. Cheapest I could find was $800 just for parts in Canada. Between shipping and border fees.
That was a heated, turn signal tow mirror.
Bastards.
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
    • Engine Wear and ISO 4406   1.) Cold Starts. 2.) High Particle Count. 3.) Low operating temperature viscosity and high low temperature cranking viscosity. 4.) Depleted AW, Friction and Acid packages.  5.) High engine load.    https://me.caltexlubricants.com/en_me/home/learning/from-chevron/heavy-duty-diesel-vehicles-and-equipment/The-Importance-of-Clean-Engine-Oil-and-Its-Impact-on-Equipment-and-Business-Performance.html   High particle counts have five sources. 1.) They are manufactured within the engine. Both wear debris and amalgamation of degradation products and combustion driven soot (worse in GDI). 2.) They are ingested via intake air. Ever hear the best oil filter is a good air filter? 3.) They are entrained in the fuel. 4.) This one is insidious. They are introduced in 'fresh oil'. 5.) They are introduced during the oil change.   ISO 4406 is the test that measures and quantifies the combine effects of all of the above particle related issues. You can mitigate your way into multiples of engine life by being attentive to them all.    https://www.hyprofiltration.com/blog/is-new-oil-clean   (from the link above)    [Quote] What Is the Recommended ISO 4406 Cleanliness Code for New Oil?   A good upper limit for new oil cleanliness is 16/14/11 (ISO 4406). Typical new oil usually has ISO codes of 19/17/15 or worse, which is far too dirty for sensitive components. This can be a major cause of degradation and premature failure. [Close quote].     Source of graph: Machinery Lubrication (GM Study)
