My 2014 Sierra SLT in Summit White
Hey everyone,
Got rid of my 2012 M5 and picked up the truck yesterday and got busy today.
I debadged the whole unit, except for GMC logo's. I even took off the chrome door ding gaurds or whatever those are. DO NOT TAKE THESE OFF!! what a pain in the arse. One i got all the sticky stuff off I noticed GMC did not match the paint, they even put arrows in the paint to show where the chrome gaurd goes. I will try to get a close up you dont notice it from a distance but when you approach the truck you can see the discrepancy.
I also plasti-dipped the GMC emblems, mirrors and couple door handles. The white with glossifier does not match summit white so I might go with black instead of chrome. Opinions are welcome.
Here are some pics.
  • Replies 58
Nice truck
Question, what is with one black handle and one white?
Nice truck. Sorry bout the chrome door guards. I want to take mine off but I was waiting on someone else to do it. Sorry you had to be the one to find out. I would go with the white door handles if you can get them to match. Can you get a close up picture of the arrows on the door?
+1 , I think the all terrain wheels looks the best of any GM wheel. The wheels + the LED lights was the reason I got the GMC AT...
Nice. I wasn't a fan personally of the amount of chrome on the SLT, and that was biggest reason I went with the SLE.
The All Terrain option takes a lot of that chrome away.. with colored bumpers, grill, etc. hardly none up front or in the rear.
Damn everyone got better wheels than me lol! I have the polished 18s on cuv crap tires, rims are growing in me but tires aren't. I have summit white also and love the color although I like the chrome, I also removed the "4x4" emblems (are those from autozone? Seriously) and the "sierra/slt" emblems in back.
I think I'm going w/ some 275/70/18"s on the stock rims to give a tougher look.
Nice looking truck! Enjoy!
Btw - I also went from a fast dd sport sedan (g8) to a truck, was odd at first but I like the size and utility.
    • Monday looks like a good day for the dealer to test an ac issue. Hopefully it all turns out good.
    • Paid $2.72 for E85 today.
    • Welcome back! No, it definitely doesn't pass the sniff test. Even "ceasefire" needs an alternative definition these days.    $5.29 at Kroger today
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • 2024 Silverado 2500 HD LTZ grille no camera Parts list   84603331 84913656 84913657 84913654 84913655 84911567 84911568 85646092 85646093 85797921 85797922   11570637  x10-15   grille/bumper bolts 11546500  x10      grille clips 11571006  x10      push/retainer clips 11546454  x6       nut retainers 11611609  x6       M5 bolts 11610700  x6       molding/trim retainers
