Hi, new girl to the forum with a question
JStorry
Hi, I'm Jess.
I work in commercial truck repair shop and have a 99 GM Sierra (K2500)
I've been reading stuff on this forum, and it has helped me diagnose many issues.
I've hit a point now where I need to replace my engine. It's a 350 Vortec, and it's seized.
I've been getting quotes to re & re a crate, and they have so far varied from 18-21 hours.
I'm not sure what is reasonable for labour, I have no access to SRTS on that
I know many people think I'm crazy for wanting to put a new engine in such an old truck, but I've done a fair bit of upgrading on it, and I don't want to start over again. For example, I just put a brand new Gibson exhaust on it in July. I don't want to part it out and though I am mechanically inclined, I don't have the skill or finances to start over customizing a new one
I guess what I am looking for is an idea of the time it would take to put a crate in. Does 18-21 sound reasonable? Thank you in advance for taking the time to read my post :)
18 to 22 hours sounds a bit high. If a shop is doing it they are going to overcharge but if you have it done in a friends garage who has experience it can be much lower. For example my friend did his 78 Scottsdale in less than half a day. And this truck is lifted. 350 crate motor.
If I get it done by a licensed mechanic I get 3yr/160,000km warrenty on the engine.
If I get a friend to do it, I may not get that. I work with 5 mechanics, but the only one I would trust to do it isn't licenced.
I know the shop will mark it up, but the local guy in town here has already offered me a better quote than GM itself.
So I've decided to order in a new water pump and new intake manifold for the job to make it a little easier on the guy working on it, and I figure we might as well replace that while we are in the engine. I'm also planning on new distributer, spark plugs and wires... anything else I should get?
Thanks again!
Welcome.
You have done your homework. The hours sound about right. I say install it with some help and that way you know it was done right, no short cuts.
My 6.0 swap took about 2.5 days of labor at a shop. They were only open from 8-5
Sent from my Samsung Galaxy S4 using Tapatalk 4
    • I know; crap pictures.   Anyway, as a finale of sorts to this thread, I had replaced both differential covers and since they had the capability of adding temperature probes, I did that. These are MaxTow analog/digital gauges with stepper motors. They'll flutter around like crazy for a moment and start at a nominal 100 degrees Fahrenheit.   I drove a 30-mile loop to the grocery store, averaging 70 MPH (as much as 80 to see if there was a quick spike in temperature. The air temperature is 102 (ambient ?). but the first pic is 7 miles into the trip. The second is getting back into the truck after leaving the store; differential temperatures dropped about three to four degrees in 15 minutes. The third pic in on the road to my house, about a mile away.   In that run, I saw a high of 150F on the rear differential, and 121F on the front. I'm sure a longer drive or towing will see higher than that, and when that happens, I can update the observations.
    • You don't want to become predictable now, do you? 😏
    • Fully warm, coolant temp >194, closed loop.   Run time can be anywhere from just reached operating temperature to having driven 30+ miles.   The O2 chart (which is a feature I just discovered after reading) for the bad idle seems to be "most" of the time. For the little time I've been watching it (scanning and driving! watchout!) I can't seem to isolate any cause or condition yet.   It definitely idles rougher sometimes than others and so far what I've seen is the rougher idles are always rich. But not enough to set a CEL.   In other news I replaced the starter solenoid. Everything on this truck is such a PITA. Starter "snout" is mangled up with the torque converter inspection cover which is tangled up with hard cooling lines and the driveshaft. But I got 'er done without too much swearing...I just go into everything now knowing it's going to be a frustrating mess.   The starter solenoid replacement kicks off the next round of work: AC, injector rebuild, cat, exhaust. I'm just going to do it all. But first:   I don't know what my fuel pressures are. I can't definitively say the issue is the injector without first verifying fuel pressures and any leakdown. I "rented" a test kit ($199.99 at O'Really's ...intentional misspelling). They don't "rent" tools anymore, they charge you for the tool and then you return it when you're done. No joke. It is listed as a rental on the receipt but the guy told me there's no difference between renting and buying  now, you just return it when you're done and they refund the credit card. Mmmkay, whatever.   I will rule out fuel pressure issues (too much), and any leaking (that's how I'll know the problem is inside the intake). I think someone said the return line could be plugged or not flowing and that could cause high fuel pressure (and too much fuel being pushed through injectors). I'll cross that bridge if I get high readings.   As of now I'm ready to tear off the intake cover, extract the injector, and have it sent off to be rebuilt just so I can rule that out.
    • What are the conditions of this rich idle? Warm or cold engine? Run time? Does every idle look like this or only sometimes?
