The air separators from an air compressor only trap a small amount. And for any brand, really need to do a test as laid out to see first hand. If you get one of the truely effective units (yes, I still come back to the ELite E2-X as it is the one shown to outerform all others in the dozens and dozens we have tested) then most all is trapped and the issue is not an issue any longer. The first empty when you add the E2-X will be a greater amount than the subsequent generally as your now evacuating at all times so your removing much of what had already accumulated in the crankcase. As far as using a can that the test results have not been done, or one with only one exit port, you are goinf to see issues in the future as the GDI engine is far diffeferent than the port injection engines of the past.
Then, I have covered the use of seafoam and similar solvent based cleaners and unless used right from the start before the deposits form enough to cause damage when you use them, you will have scouring to the pistons and cylinder walls as well as other potential damage. If used in conjunction with say the E2X system, they will help maintain deposit free valves for the life of the engine.
Not that the E2-X isn't but, it looks like the ADD W1 is fully serviceable and it appears guys have had great success with them. At only 1500 miles and a CRC/Seafoam regimen is still recommended, the ADD looks like a inexpensive alternative to the E2-X. Do you guys cut the existing pcv connectors off of the factory pcv tube and reuse them for the catch can?
Edited by Willshire
I have the e2x and it is fully serviceable. All the internal components can be accessed and cleaned. It is a professional grade part. I am amazed of how much it collects.
It's serviceable but not without completely removing it and you can't see the inside of the can. But yes you can spray carbeurator cleaner inside and shake it up and then rinse it out.
Should we be doing this to our Elite catch cans every so often? Edited by mjj
I would think we should be checking the media for buildup but, since it doesn't see the heat the back of the valves do i can't see the oil and water bonding to the media very much. A check once in a while is just good maintenance
Not doubting the effectiveness of this can at all. As a matter of fact it looks very well engineered. But with the CDN dollar in the crapper, this is an almost $500 dollar part.
Put straight pipes on it and use a crankcase evacuation kit! LOL
Edited by Willshire
And it is for a port injection engine, but GDI cannot tolerate any oil ingestion, so that is what the owner needs to take into consideration. Running a can that only traps say 30-50% of the oil mix entering will help some, but still result in coking. When you take into consideration the added MPG the E2-X gives, it is a no brainer. But everyone is free to install what they choose. I can only pass on actual testing results and there are not many that can come close to the E2-X, and none to date that exceed it.
On cleaning, they should not need to be cleaned. All Elite are billet threaded and O-ringed to be able to service, but again, in testing any of the cans rarely did any need to be cleaned no matter the brand. If they operated inside the engine where temps are high enough then residue would bake onto the internals, but as all cans cool the vapors substantially, none need to be cleaned except at say 50k mile intervals just for maintenance if desired. The longest test we have done is 63,000 miles and on inspection very little actual build up was anywhere internally.
jsdirt, AMEN to that statement!
What ever happened to the old days of sucking water into the intake via manifold vacuum and steam cleaning the valves? Those days were awesome!
You would never really clean the tops of the valves by doing this...even in the old days. This method of water injection just cleans inside the cylinder. so the backs of the valves might get cleaned, but the issue still remains with the tops sides of the valves.
i just figured water droplets rushing in to a 350 degree valve (assumption on temp as i know the valves are hotter than the coolant.) would turn the droplets into steam just as they were approaching the valve. I'm not an engineer so this is pure speculation.
Physics forums:
Water does a nice job decarboning the piston/cylinder area but has virtually no effect on the intake side of the intake valve or EGR passages and that is where the majority of carbon build up happens. This is much more of a problem in direct injection engines. The PCV system functions to recycle combustion blow-by through the intake. It builds up on the intake valve where the venture effect causes low pressure and the combustion contaminants condense out and adhere to the valve head. This requires chemical or mechanical removal and can not be removed with water. You can decarbon part of your engine with water, but you are treating the part of the engine least affected by carbon buildup.
Reference https://www.physicsforums.com/threads/decarbonizing-an-engine-with-water-myth-or-fact.793344/page-2
Physics forums:
yep, pretty much exactly what I was getting at.
Looks like a BG style cleaning every so often (15k) is warranted anyways. I pity the guy down the hall from me that has 50k miles on his silverado and these things don't even ponder with him. He's a 3-4 year turn and burn guy anyway LOL
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 2,793 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
