What is the AN size on the RX can.... I'm wanting to do the Dual exit mod. I'm guessing -6 but not sure
RT
When I did the upgrade on my RX can I used a 3/8" drill bit with a 1/4" NPT tap. Hopefully that helps you.
For GM applications 3/8" id hose, or -8 AN lines will work with the AN style clamps.
Ford takes mainly 1/2" or a -10 braided AN line on most.
So a -8 to 1/4 pipe nipple and a -8 90 degree 3/8 barbed fitting correct. I'm using standard 3/8 rubber hose and want to get the same size 90 degree fitting and straight fitting as the original ones. -8 sounds too large to me
RT
Edited by 07Softail
-8 is half inch, -6 is 3/8. -10 is 5/8.
Correct, but the AN braided line as far as fitment over a push'lock AN fitting works the next size up. Trying to push the -6 over 3/8" barb is very difficult so the -8 fits slightly snug, and then use a AN clamp end to secure them and so on. The Elite cans come with true AN screw on fittings, so then the -6 would be used, but it is then difficult to fit the barbs into as they are a 3/8" barb. I think most get the push-lock style AN fittings so if wanting to use the braided line, then using the next AN size up makes it easier for the installer (as long as you use the AN clamp ends like these:
http://www.summitracing.com/parts/fra-280208
This makes a nice clean install when used on each end of the braided line at the checkvalves and other fittings.
Thanks!!!
Got my catch can in yesterday. Not a single direction in the box. I told them I wanted to mount it in the spare battery location. So since there's no directions, where does it actually mount? To the bottom of the battery tray? To the battery tie down support?
Edited by knkguillot
I think I used the bolt holding the windshield washer bottle to attach mine.
Sent from my SM-G900W8 using Tapatalk
Well the only place that made since with the bracket they supplied was to bolt it down to the bottom of the battery tray. I'll get pics shortly. Hopefully I did it right.
Here's how it's mounted. Has anyone else mounted it like this? It's bolted down to the bottom of the spare battery tray.
Here's another mounted in that area. The way you have it doesn't leave much room for drainage.
http://www.gm-trucks.com/forums/index.php?/topic/186456-Throttle-Body-Pictures-w/-Elite-Catch-Can-&-Clean-Side-Separator&do=findComment&comment=1798828
Flip the bracket around to attach to the washer bottle. That said I have a piece of 3/8" stainless tubing off the valve on mine thay drains over past the pcm so I can easily get a pop bottle under it
You'll want to mount it like this?
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 472 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
