2014 Sierra All Terrain 6.2
Edited by gmcok
Waiting on tires to come in, then bed liner, tint, paragon cover, color matched handles/mirrors, etc.
th_DAA3CDE1-919E-4B1F-8CF2-BA25E49759B9.th_23A98742-44FE-4C94-882B-02A8287A5A98.
New here. 6.2 max trlrng with 3.73s added bed coverand front floor mats
Edited by Ulukslo
y3ehy2av.jpg5u6u5a3e.jpgy3y8a6a9.jpg this is mine. Base model got it with 4 miles. V6
1.leveled $80
2. Step $130
3. Plasti dip the letters and badges (including the steering wheel one)
4. Installed led on footwell and step $12
5.changed every yellow bulb to white led $30
6.installed 5k Kensun hid kit $50
7. Front window tint to match the rear. $30 at the local flea market.
8. Also installed an led on the rear bumper step connected to the reverse light. Either for helping when reversing or when at night you need to get on the bed to get something out. Just press the unlock button and it lights up.
Coming soon
1. Putco g2 dayliner
2. Line x
3. Weather tech floor mats
4. Wheels and tires
5. Audio system
Sent from my SM-N900T using Tapatalk
Edited by NitroDatsik
RC 2.5" suspension kit...highly recommend it as it's MUCH better than the kit I had on my 2012 that just had spacers in the front. Tires going on in the morning - will post more pics when I pick it up. Sent from my iPad using Tapatalk
I was looking into the 2.5" and thought that was the ticket but then I looked at the 3.5" RC and liked the fact that it came with new upper control arms to correct angles and replaceable BJs. Only problem is (and it's not a real problem) I will be on stock tires for a long time. Was worried it wouldn't look right with 3.5" lift and stock tires. But, I'm guessing that it would look close to a 2500 with stock tires and they don't look too bad. I've always thought that tires totally change the look of a truck and will get something more aggressive later but cant bring myself to not get good use out of the stock tires just because they don't look cool. I guess I'm looking for a picture of a 2014 with 3.5" lift on stock tires.
BTW Michaelis01, I have the same color truck only it's not LTZ. I love it but it just needs a taller stance. Especially since I went from a Duramax back down to a half ton.
Here's mine, 3.5 with stock tires still on stock tires a6yva9eh.jpgudabu4uj.jpg
Sent from my SCH-I535 using Tapatalk
Edited by ridnclean28
Do you have line-x color match liner? Snap a pic if so thanks.
Hey sorry it took so long to get the pics, and it's a little dirty I was carrying some tires in the back but here is the white bedliner
you could always sell the new oem tires to offset the cost of the new larger tires????
That's an idea. But I've never had the best of luck selling anything. Guess I'm looking for an excuse to not level/lift right now as I do not need to spend the $$$ right now. But I am getting my wish list in order.
Come on Michaelis01! Where's those pics with the new rubber?
Ha - sorry...will get first thing in the morning. Dropping it off for tint and will snap a couple when I do so. The tires make the truck for sure. I did take one but it doesn't do it justice e5uvajaz.jpg
More tomorrow...
Thanks. 285/65/20 BF Goodrich All-Terrain T/A KOs...have had them before and they are great tires. Very quiet too. Sent from my iPad using Tapatalk
Are you getting any rubbing from that size tire?
There is a very slight bit on the inside, back part of the fender (closest to the engine) but it feels pretty flimsy right there so I'm going to look at trimming it. ysenasar.jpg
Picked her up yesterday. Introducing my 2014 Silverado High Country.
Sent from my iPad using Tapatalk HD
Picked my Max tow 6.2 up 2/18/14 119 days after I ordered it. Swapped the factory Goodyear all seasons out for a set of Cooper Zeon LTZs yesterday.
Craig
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 1,921 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
