I did. I used the hypertech calibrator. If fixed the speedometer and seemed like if changed the trucks shift points
Did you do this yourself? Is it easy to do if so? I've never had a vehicle til now that I could really play with as much as you can with a truck. Trucks and AR-15's are to me what barbies are to girls lol. So many ACCESSORIES!
I had an edge evolution cts programmer in my old truck, it was awesome and super easy to use. I can't speak for them all, but I'm sure they all have the same minimal learning curve though. I ordered 2 tunes: one for more performance and one for better gas mileage. It came with a few canned (or stock) tunes loaded on it as well that would help some. I wasn't able to flash the trucks speedo with it though when I changed tire sizes (had the stealership do it). The unit had a descent size screen and you could display various types of information with speed being one. I simply entered the new tire size and it showed my correct speed on the cts, which was a few mph off from the speedo once you hit about 65ish. It was basically plug and play in the odb2 port and follow directions on the device screen. That was with a truck from the dark side also, gm vehicles may be totally different.
Edited by SkeeterMcSkeet
Thanks. Appreciate the info.
Hey my truck was built at Farley's too!!
Greg the owner is a good friend of a friend of mine. They do all of Wheaton's trucks, is that where you bought yours?
I'm still trying to justify spending over $500 on those Bulletproof flaps, but they really are the nicest out there.. and will save the paint from our horrible roads.
Yes I did. It took all of 10 minutes to do. The only negative thing is I had to borrow somebody's computer to update it out of the box. The reason I did is it can't be updated with a Mac computer.
mine has all options except driver alert awareness and rear power slider, I think something else too but nothing I really had to have. I do have the 6.2 tho.
How is the 6.2? I got mine before they released the 6.2 and am kinda regretting it.
Here's my 14 All Terrain
7inch RCX lift on 37's and 22's
6k Hids in heads and fogs
Lifted14gmc. What kinda setups is your HIDs....? I got a cheap set off Amazon and never installed them. Did you run a error code eliminators and relay? ?? Thanks
I did a walk around video on my truck.
What tire shine do you use?
I used the kit off of "strictlyhid" came with code eliminators, relay,, fuses, everything down to the zip tires to hide the wire! Highly recommended.. Easy to install all plug and play! No problem at all
Gobbs of power so glad I went that route not to rub it in but it's awesome
Mike, I use a stuff called smartiredreassing made by smartwax. It's unbelievable.... it doesn't come off and leave marks all over the truck and driving through dirt it doesn't cake on either.... I found them on Instagram and use all of their products now.
I'm besties with Cara. I bought my truck at schwabs in Leduc. I did the bulletproof and I'm happy.
