My 2014, the day I brought it home in October, with only 27 miles on it. I've since de-badged it, tinted the windows, and Line-x'd the bed.
Leer was a bit less expensive and the dealer was closer to home. By the time you add up the options on a 550 the 700 is less expensive also...The cover is holding up fine, no leaks.
Ok here is my new 2014 Silverado 1500 LT on the day that I took it home from dealer.
I posted in the new member forum if you want to know more about me! This is my first Chevrolet vehicle
2014 Sierra AT SLT 6.2
Guapoh,
Rig looks awesome. Did you put lift/level on it?
What kind of tires?
-disregard saw your other post.
Edited by RoadWarriorMax
Here's the new addition. Slightly used gm dealer vehicle.
2014 GMC Sierra SLE crew, 5.3L, 4wd, 17's, summit white on jet black, 40/20/40 front bench, "preferred package", liners inside and out.
IMG_20141224_111409-Blackedout_zpsf44e10
Ending 14' in the back of my 14'
530F93BF-FF38-43C1-888E-D870DE2BC368_zps
How cold does it get down there that you bundle up like that?
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,307 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
