It was that way right after getting it all done before was freezing. But a little worse since got colder.
Those Toyo R/T's are 78 lbs in a 33. I bet your closer to 90lbs in a 35.
I chose not to get them cause of the weight.
The Goodyear Duratrac are 48 lbs in a 33 and the Toyo AT2's are 58lbs in a 33.
I bet its all that weight, still seems really low.
Edited by frenchsquared
I don't think I ever compared the difference in weight between R/T's M/T's and trail grapplers.
I have spent the last week doing exactly that.
I wanted the best look and best millage. Those R/T's are stupid heavy.
Favorite truck on this site by far.
What is your wheel/tire size again?
Thanks man, I appreciate that! Wheels are 18-inch Method Mesh with 275/70/18 tires.
Edited by DLS-001
Here's my 14 All Terrain
7inch RCX lift on 37's and 22's
6k Hids in heads and fogs
What wheels are these?
If I remember right my toyo MTs are around 60 ish pounds in a 33
The new Fuel hostage 2s 22x12's
Got my 2015 Sierra in October. First Truck I've ever bought, and am happy I did! Hardest part is not pouring piles of money into it...
So far:
Ready lift 2" level (has 4" blocks in back, changing to 2" blocks)
275 60 R20 Goodyear Wrangler Adventures
Spray in Liner
To do:
Borla Atak Dual split side exit exhaust (In the mail)
Airaid Cold air intake
285 60 R20 Duratracs (once 2" blocks are on)
Bushwacker flares
Potential to do (input appreciated!):
Front window tint (not sure %)
plastidip emblems
remove air dam
anzo tail lights
black out all chrome
Picked up at the dealership
First drive (bigger tires on now)
Cleaned it up
Random pic
Edited by Blairh12
So far:
Spray in Liner
To do:
Bushwacker flares
plastidip emblems
remove air dam
anzo tail lights
Cleaned it up
Random pic
Headlights make a HUGE difference
Edited by John_chadra1
that truck has a lot more then a 2" level on it.
That is a sick looking truck. Love it and I don't like the blacked out look, typically.
They're 75 lbs. Which is 5 lbs less than M/T's. I'm still looking at others but Cepaks are about the same. Can't find numbers on trail graps yet.
Tire shop I asked must have been wrong.
I know they said a 33x12.50x18 was 78 lbs. That is way to heavy for me.
I did not look them up on my own.
Directly from Toyo's website:
Fullsize:
Edited by hutch08
It's hard to see the numbers in those images for some reason, but if you go directly to www.toyo.com you can view the weights and other specifications of each tire.
Width has a lot to do with how much the tires weigh, I was initially planning on running 305/55r20 (33.2x12.4) Toyo AT2's but realized they were 74lbs a piece.
By simply going down to a 295/55r20 (32.8x12.2) Toyo AT2 they only weigh 60lbs, that's 14lbs per corner is a lot of extra rolling mass for an extra 0.4" in height and 0.2" in width.
Both have the same tread depth, but the 295's actually have a higher speed rating and greater weight capacity than the 305's.
    Chris80s
    Chris80s
  • Who's Online   5 Members, 0 Anonymous, 921 Guests (See full list)
