The highest I have ever got was 15.6. I am about 60/40 city though. I understand that city driving is worse, but to be 3 mpgs worse, at my best, then what city is supposed to be rated at is a joke. My last tank I was at 13.1.
My "best 25" is 21.8 "best 50" is 20.1, "best 400" 15.1. 3500 miles and my mileage gets worse every single fill up, like I said my last tank was 13.1.
I also watch my mileage the whole time (and my fmaily thinks I'm nuts and laughs at me the whole time), and drive like a Grampappy. Coast when ever I can, and drive 65 (70 mph speed limit) on hwys, 45 (55mph) on country roads most of the time. I've never drove like this and it's starting to not be worth it, I wanna ripppp!!! :driving: lol
Fellow Michigander, your MPG is only going to get worse with these cold temps and snow.
I understand that too, but if I drove this truck like I would normally drive I'd be under 10 MPG. Thats just silly.
Yeah don't get me wrong, I do like my iridium but it's not exactly the color I truly want. But it's close. And yeah black wheels on grey or charcoal paint is my favorite setup right now. Then all black is my second choice. Ford has a grey I like. I just am not much of a Ford guy. Except the raptor is sick.
I have always had all black. So I decided to switch it up and try the Iridium, pretty happy the way it turned out. My biggest complaint about these new trucks, is the damn paint is ridiculously thin!
Edited by John_chadra1
  • Like 4
Was at the hunting camp this weekend and thought id take a couple pictures.
693389AE-7FAD-403E-B6A2-4C537740A5E9_zps
2DC3BA20-BFC2-43A8-B85C-4CDD9944E510_zps
  • Like 12
Excellent looking truck Joel! Given thought several times to that 3.5" rough country kit. Though buddy of my brothers running his older 2011 GMC with that kit plus trail grapplers was getting horrid gas mileage.
How is yours doing?
I think my truck is on the low end of the spectrum when it comes to the 14s. I'm getting 12-15 in town stock and 18-20 highway at best. It's more like 13 city, 17 highway.
Thanks will! I am continuously adding things to it because I'm sure you and everyone else on here knows, you're never completely satisfied with how it looks you always want to do more! up here we go by litres per 100 km so im not sure exactly the fuel mileage but I can tell you it has definitely taken a significant hit
Looks great... did you clean it up once you got 2 the camp?? I would've
Thank you!
No, shes actually dirty in those pictures. Its just hard to tell with the truck being silver.
Edited by Tim99GT
  • Like 3
better do it now when gas is cheap. Only going to go up from here. Last time I remember 93 being $2.50 was in '05.
Here's my bone stock 2015 Sierra All-Terrain "before" pictures for reference. Plans are 2.5" RC kit up front, gonna leave the stock blocks in the back. I'll swap for the RC blocks if I have less than 0.5" rake or looks "nose high".
It's also getting 295/55r20 (33x11.5) Toyo AT2 Xtreme tires on stock 20's and black Bulletproof offset mud flaps. Should be done after the weekend, I'll report back with "after" pictures and measurements.
Here's a little bit of an update, got the Rough Country 2.5" kit installed up front and the 295/55r20 Toyo AT2 Extreme tires on.
Decided to leave the stock blocks in the back for now, had the shop send me a couple pics and take a few measurements.
Currently sitting at 39.5" up front and 39.75" out back from ground to center of fender.
I'll give it some time to see if it settles and if I change my mind I can easily swap the rear blocks.
Just have to get the BulletProof offset flaps on, tint the front windows and get the front bumper PPF installed.
Hutch what were your original measurements? I've been thinking about getting a 1.5" block if i don't have a half inch of rake or better.
Unfortunately I never got a chance to measure it before the work was done... and every truck seems to be a little different, especially with different cab/box configurations.
Here is the specs from a 2014 Silverado 1500 LTZ Crew Cab Standard Bed with the full RC 2.5 kit and 305/55r20 tires:
Stock height with 275/55r20: 37" Front 38.75" Rear
Leveled+Block with 275/55r20: 39.5" Front 39.75" Rear
Leveled+Block with 305/55r20: 40.25" Front 40.5" Rear
His seem to be lower in the rear, but that could be due to the added weight of the longer box. I know the Ext Cabs tend to have more rake than a crew cab.
There's a couple members with the RC 2.5 kit and the general consensus is that on a crew cab with a stock rear block you'll be about 0.25-0.5" higher in the back.
One member with a 2" front only is sitting at 39/40, another like mine with the 2.5" front only is 39.5/40.
In theory, if I swap the rear blocks I "should" have approx. 39.5/40.75 fender measurements with 1" - 1.5" of rake.
So depending on what you want, it sounds like the supplied 2" block will be enough to give you the rake you're after... or just leave the rear blocks and only do the 2" front kit.
Here is a walk around video with up close of the level kit.
That rendition of Metallica is hilarious.
I had to turn the sound off, it was too painful to listen to.
Agreed...and I REALLY LIKE Metallica...when it IS Metallica.
Edited by patriot
    DM22
    DM22
  • Who's Online   0 Members, 0 Anonymous, 2,212 Guests (See full list)
    • So I'm in the middle of a DOD AFM delete on my 6.2 L86 Sierra. I had a pick holding the tensioner but after I got the Cam phaser gear off I was cleaning off all the rtv and apparently I didn't have the pick seated far enough in. I bumped it and the tensioner sprang forward.  I think everything is good but I want a second opinion. The top of the tensioner is just a looped piece of plastic that rides in that channel right? There is no spring or anything is there? I got the gear and chain back on and it seems tight and everything looks right. I'm hoping nothing fell out.
    • My 2015 1500 LTZ Silverado suddenly won't go into 4 x 4 low. It will go into 4 x 4 high.
    • Yep, just a quick reference point.    My main point being I’d do a thousand other things before I’d pay 10k for a transmission.    Speaking in ignorance cause I don’t look at these trucks, what is it worth? 20k?
    • I think users are going to want to pick their monitored parameters, which parameters they want to see first.    It should probably start with baseline at a minimum and adjust to learned, but be able to overlay baseline for comparison.   A simple severity level would be able to determine what type of alerting is appropriate or user selectable.    Why not use the OBD port though?   I think a phone connection would be a good idea, push notifications type deal.   Number 1 issue is having data is useless if you don’t know what the data should be under normal conditions.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
