Got it off EBay, I am very pleased with how it turned out! I am a sucker for hood decals,, I have put them on every truck I've owned..
Here is the link.. You can mix and match red, silver or black.. Very good quality vinyl
http://m.ebay.com/itm/5-3L-Ecotec3-2-Hood-sticker-decals-emblem-Chevy-Silverado-GMC-Sierra-Z71-2014-/261310172638
looks good
After I got the RC 2.5 Level installed, new wheels, and exhaust. Love it :drool::drool::drool:
Edited by Skelly
2016 Z71. 3.42 gears. Black Widow Exhaust, Tint all the way around. 305/50r20 Cooper Zeon LTZ on 20x9 0 offset novakane wheels. Rear block removed. Before anyone asks yes they rub when turned all the way but just on the rear. Gonna do a little trimming they actually don't rub that bad. Also my factory rear lift block is removed...don't know why but it seems like it helped clearence.
looks good
2015 Z71 2LT 1500 4x4, 3k miles, sides tinted @20%, cleared headlights, 2.5" level kit, 33x12.50r22 toyo mt on 22x11 -24 fuel hostages, painted emblems and trimmed valence
9BB190E5-8FC3-408B-BDD0-851A14AD464D_zps
E529A571-1BEB-4845-9E38-6A00BCD6EF70_zps
A6B2E9A5-65D5-4F2C-9445-D72E05865CCC_zps
Edited by roundsy
  • Like 9
I like that.
