831f9c13b7873727c8d27d1a20dfbd47.jpg4b0ae1c081ff2ac9c7db51227a9dd6c2.jpg59b563b8ee4a7f82f0d1d03c2974d9a2.jpg
Haven't had time to get her all washed up, but boy have I missed my truck!!
Sent by a simpleton struggling to operate an iPhone.
  • Like 7
2016 tungsten metallic z71
2.5" rough country level
295/55r20 toyo at2
20x10 -24 offset moto metals
  • Like 8
295/55r20 toyo at2
looks good. might want to take the tag's off your tires (2nd,3rd photo)
295/55r20 toyo at2
Looks great!
I have a black 2016 chevy silverado Z71. I put a set of factory reproductions black style 34 22" wheels on it. I have'nt been able to post pictures because when I try it says the file is too big.
Badass truck. Thanks for posting all the details (like the overall height for garage fit!). Are you running the spacer on the front to clear the OEM rims or spacers on all 4 corners?
My 2015 Z71, 6 inch BDS, American Force Blades with 35 TY
Nice truck , I like to see some reg cabs , anymore pics ?
No spacers needed to clear the wheels. I do have 1.5" hub centric spacers on the rear only to correct the track width since the lift pushed the front wheels out right at 1.5" on both sides.
2014 Sierra SLE Z71
2.5" with 2" leveling kit
SLT headlights
295/55/20 Nitto Trail Grappler
  • Like 7
2014 Sierra SLE Z71
SLT headlights
Awesome single cab!!!
2014 Sierra SLE Z71
SLT headlights
Looks great!
5in RC lift
18x10 -24 Moto Metal 962's
285/65 Nitto Trail Grapplers
RC steps
K&N intake
5in RC lift
RC steps
K&N intake
looks good
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
