What is in the GTO or how heavy is that trailer to be 8500lbs?
Tyler
7500lbs Tyler, GTO 3900 w/ cage, 3200 on the trailer and 55 gallon of VP in the bed
Has anyone tries 33x12.50r20 on stock 20 in wheels with a 2 in leveling kit?
it will rub...
i have 33X12.50X20 on 2.5" level and it barely rubs the sway bar at full turn...nothing else
Ok, I'll start looking there then. Do you have a pic of the work your buddy did? Just to see how it turned out.
Sent from your sister's house
Nice! What are the specs on the GTO (the more detail the better). I still keep in touch of the guy who bought my 06 in case I ever want it back (sometimes I do).
Tyler
I'm running them. ToyoAT2. They're heavy tires. I have the 6.2 and the tires have affected fuel mileage but look and ride great. Great off road performance. Slight rubbing on sway bar at full lock.
Can you post up some front on and rear look pics? Those x10s and the -24 offset make those 285s look really big!
Sorry about the delay. This somehow slipped through the cracks, but here ya go. d9aab0c8d662336caa60862fd998ae1a.jpg53b83b9023b603f453d317264c842070.jpg
And you only have the 2in leveling kit and not the 2.5 right?
That's a big looking 285!!
Tyler
Boooo! This is a truck forum....talk about cars somewhere else.
Edited by bcbz71
Picked this one up on the 4th of July! Just broke 1700 miles, this is a world of change from my 09 LT with 143K!!!
  • Like 4
It's essentially a 32.6" x 11.2" tire, so not much different then a 33x12.5. I am very happy with the look and heard nothing but good things about the trail grapplers.
Nice A/T in that blue color, how does you hunting buddy like the new ride so far?
    • I have 2 choices.
