Sure no problem... It's nothing fancy just not sure if there are many other white and black themed exterior trucks with brown/tan interior. I've got a lot of complements on it, but I know everyone has their own opinions.attachicon.gifimage.jpeg
I'll try and take a few more pictures in a min, stuck at work.
That looks awesome, I actually liked the Cocoa/Dune interior only reason I didn't get it was for that exact reason I didn't want the seats that tan color. Good job!
Thanks!
I'm not sure How these will show up, it's not letting me post any of my pictures.
About an inch and a half. No wheel spacers. It doesn't bother me all that much. Ill get some down the side pictures when I get a chance. It'll probably really bother me after taking and looking at the pictures though haha
Sent from my SM-G928P using Tapatalk
IMG 20161015 135442422
IMG 20161015 135305233
Got my 5100 Bilsteins installed, rear only. Not going to level i like the way it sits
Michelin Defender LTX
Planning the exhaust
Why did you only do rear? I'm looking to do front and rear soon.
First check ride with camper i wanted more rear suspension control.
I'll start there put the trailer and bars back on go for another ride.
I like the way the truck sits, don't want to raise front.
So if I decide I need more front control Bilstein 4600's will be going in
#8000+ depending
Headed on 3500+mi trip Nov 16
2017 Denali 6.2 Mineral Metallic. Chrome Delete, Tow Mirrors, Tint, wheel spacers & Leveled post-164840-0-57571100-1478352829_thumb.jpgpost-164840-0-04854500-1478352857_thumb.jpgpost-164840-0-63372600-1478352870_thumb.jpg
  • Like 4
#8000+ depending
You can still install the bilstein 5100 on the front, just set them on the low setting and you won't get any lift.
#8000+ depending
I'm putting hellwig 987's on soon. I'll keep you posted.
Sent from my Nexus 6 using Tapatalk
Been creeping the forums for a little while and finally decided to post. Currently have a 2016 Silverado LT Z71 purchased this past August. Only got to drive it for a day before I had to go back overseas.
I had 2011 Colorado 2LT Z71 before I bought this. It got totaled in a hailstorm. Crap scenario, I paid the Colorado off two weeks before this happened.
Pretty much, Colorado got totaled and I either had to wait and buy a truck when I finished my tour, or buy one immediately. Just in luck, Chevy was offering 16% off on double cabs when I this happened. Within a week, truck got totaled and bought this baby right before I left.
Bought the truck for an awesome price, great financing, and now it's sitting on a heated, fully protected garage getting started and driven 2-4 times a month. Not what I wanted, but I couldn't be happier with the truck. It is gonna get put through its paces when I drive it from PA to Alaska in a few months.post-164854-0-49412900-1478357129_thumb.png
Edited by Canine
2017 Denali 6.2 Mineral Metallic. Chrome Delete, Tow Mirrors, Tint, wheel spacers & Leveled attachicon.gif2017 Denali 1.jpgattachicon.gif2017 Denali 2.jpgattachicon.gif2017 Denali 3.jpg
Looks great. Great color combo. What size spacers are you using?
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 1,858 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
