The Z dirty
The Z clean
Sent from my SM-G928P using Tapatalk
looks great dude!! What's your tire/lift setup?
Hi what back space and offset are you running?
Offset is -11. Sorry I'm just getting back to you
looks good , how do you like your running broads ? wish mine was that clean
I love em. Hard choice between the amps and these. But $1400 was hard to justify for something i just use to get in and out of the truck.
The Z dirty
The Z clean
Are those nfab running boards? rough country?
Nfab textured
Edited by Clasick
Heres my 16 with 4.5" lift with cst spindles and 1" rear lift. 285/75/17. Absolutely love this truck but unfortunately I will be lowering it back down to stock with just the bilstien leveling shocks and smaller tires.
A090622E-D5DA-4A95-9CA3-49C21B90E875_zps
C9677868-A718-4904-8760-4215948BDE7C_zps
  • Like 3
Looks good. Lower it?
Yeah because I'm having issues with these lower control arms. So i need to put my stock lower control arms back on and the stock spindles since they do not have the correct lift spindle to fit for the new stamped steel and aluminum arms.
But i just found out they will be coming out with the correct spindles soon so i will not have to lower it back to stock or level ride height. Which is awesome news! Keep the stock geometry and gain 4" lift.
The - offset wheels don't help either..
Sent from my LG-V495 tablet using Tapatalk
Edited by mafd2
The Z dirty
The Z clean
Clean truck! How are you liking the 4.5 Zone lift and complaints?
Thanks! Only complaint is the front track being pushed out. But knew it would happen. Other than that it's great. Stock ride. Stock angles
Edited by Clasick
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
