Thanks!
They are DeeZee NXT boards. I like them a lot. They are aluminum so rust won't be an issue and they don't flex a bit with my 170lbs on them. They are worth every penny just to protect the paint from rock chips. I added some flaps at the front to protect the the doors and some filler pieces along the back side to fill the gap between the boards and rocker panels.
187AAC92-A0FD-4926-915E-99B922E2A3CA_zps
Another question !! is the lower balance of your bumper custom ?? i really want to get rid of the chrome and plastic balance..
on another note i went with the GoRhino steps similar to yours.
Sent from my SAMSUNG-SM-G890A using Tapatalk
2014 GMC Sierra SLE Z71
Upgrades l have installed:
Window tint
Magnaflow dual exhaust
2.5" RC Leveling kit. Front only
275/70/R18 Toyo Open Country
Edited by KpruittZ71
Window tint
That's a really clean looking rig...love those 18" Z71 rims - I think they are the best looking stockers made! I've got the same thing except white and DC. Don't know if you are a "sticker" guy, but I added the older style 2013 Z71 sticker to the back of the bed.
How does she look from the front and rear? I've run 275/70 before but in BFG KO, and found them to be narrow. The Toyos may look better though.
Edited by bcbz71
Just got her last night. New to me, but used. 2015 Z71 2LT Double Cab with only 11,000 miles. Quite the change from my 1999.
  • Like 5
Thanks man I appreciate it!
All my trucks have been Z71's, so when I got to the dealer and realized that the bed stickers are now a $100 option (not sure but I think that's for GMC's only) I was little ticked off. I will say now though that it's grown on me not having them. Also don't understand why the GMC's don't have the Z71 logo in the dash cluster.
The Toyo's are pretty much flush with the fenders. I don't really like the look of big mud flaps so I didn't want a tire that stuck out and that would totally destroy my rocker panels.
2017 All Terrain.
2" RC front level
KO2s
May add the front spacers and the rear blocks, not sure yet.
Edited by fc_glk
2017 All Terrain.
2" RC front level
KO2s
It looks like it sits up there pretty good as it is to me. Nice lookin' truck!
Sent from my E6810 using Tapatalk
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,299 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
