Welcome to the site, good looking truck!!!
Thanks! A lot of great trucks.
And some good advice every once in a while...….
2018 LTZ 6.2 Max tow with CST 4.5" suspension lift.
  • Like 7
Good looking truck, did not know you get the max tow with the tow mirrors.
I swapped the tow mirrors for the DL8"s. Just didn't care for them.
Right there with you, do not like the look of the "elephant ears" that come with the package. Nice addition with the small mirrors.
6 hours ago, P_huff said:
Great looking truck! What brand/model of tires?
Found the end of the road, and some snow over the weekend.
Edited by JimCost2014
Sent from my SAMSUNG-SM-G890A using Tapatalk
  • Like 8
On 1/12/2019 at 8:40 PM, Crazy Schooner said:
new truck?  did you keep the campin' wagon?
Beautiful truck, awesome CST Lift. Congrats!
Sent from above
What’s the best “Catch Can” you’d recommend for our 6.2’s, Elite Engineering?
Sent from above
18 Denali Ultimate with RC 2.5 leveling and Air Lift load level bagsb5f20d57d855d406153b63033c0bfdfb.jpg
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
