On 1/18/2019 at 7:41 AM, mitchely03 said:
 Been meaning to go up there, im in Corona. I dont think my 2WD will make it though haha
Took my '15 (2WD) up there, no problems, but then there wasn't any snow/ice.
On 1/18/2019 at 8:36 AM, jgraves13 said:
Do you ever need chains with the 4x4? Bought some for mine just in case but last weekend when we were up there 4x4 seemed to be enough for the mostly plowed roads at least
The last time that I went up to Big Bear, with snow, they wouldn't even let 4x4s up there without chains/cables.  Still have my cables from that trip, was for my '10 Ridgeline, which was before my '15 Silverado LTZ Z71, now I have a '18 Silverado LTZ Z71.  Haven't been up there since about a year before my wreck ('15).  Maybe one of these weekends, I'll take the wife and kids up for Alpine Slides.
3 hours ago, Kurtj29 said:
Out and about this morning.
Truck still looks great! Where at this time? Still thinking about the level and smaller wheels?
Edited by JimCost2014
Thanks.  Outside Duvall on a short dirt road.  Still looking at a level - probably Suspension Max. I think I will black it out first and then think about new wheels and tires. My current favorites are the GMC OEM 20x9 - 5 spoke black wheels you see on the Elevation Edition (just like Crazyjoker77's truck above). I really like how they look - simple, clean. Got any suggestions for a local shop in the Puget Sound to do the level - that they would know what they are doing with the Magnetic Ride?
Edited by Kurtj29
On ‎1‎/‎18‎/‎2019 at 8:20 PM, TXGREEK said:
Ok, last song and still my favorite!
Sent from above
Will lean towards the Kid is Hot Tonight and Working for the Weekend as my favorites from them.
6 hours ago, Sierra_Hondo said:
Yesterday on Squaw Pass, Colorado...
Outstanding.  Squaw Mountain is where a few pieces of ham radio and emergency radio equipment resides.  Great place for broadcasting to much of the front range.    And behind it resides Mt. Evans.
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
