3 hours ago, HoosierZ said:
Seeing a similar ‘19 next to my ‘16 makes me like mine even more. Lol. Still not a fan of the 2019/2020s.
The painted front end helps.
40 minutes ago, Eloy said:
Great looking truck!
Paint or vinyl on the hood? Looks pretty cool!
On 4/16/2020 at 11:44 AM, JimCost2014 said:
Welcome to the site.
Congratulations on your new truck!
Thanks dude!
On 4/16/2020 at 10:04 PM, Eloy said:
Hood black stripes are vinyl
Was it a kit, or did you make them yourself?
5 minutes ago, P.T.B.O Cam said:
Thanks dude!
You are very welcome.
Any plans for the truck (mods)?
I purchased the truck like that from dealership
Looks good!
Couldn’t agree with you more sir .  That monochromatic all blue looks beautiful!!
2018 Denali 1500 how it sits now bottom pic is when I bought it beginning of March.
What lift and wheel/tire combo are you running?
Well so far I've had all the windows tinted, removed the muffler and put on a nice shiny tip, and basilisks maintenance. I switched it over to AMSOIL 0w-20 right away and have GM rear wheel liners on order they should be here this week.
Future plans are to get rid of the nasty steel wheels that are starting to rust quit a bit on the lip and under the centre caps. I'll get those K02's off after the summer because they're WAY TO LOUD; the constant droning is driving me bonkers! I'll also be installing my dash cam (front and rear) and will probably add an aftermarket bluetooth kit for the factory head-unit later in the summer. ? Oh and the plastic drop in bed-liner needs to go and it will be replaced with line-x.
    Frank V
    Frank V
  • Who's Online   6 Members, 0 Anonymous, 1,043 Guests (See full list)
