I know for a fact that the cameras on the traverses have higher resolutions than the garbage they outfitted in the full size trucks.
If there were a way to plug one of those cameras into the wiring of ours and see if the resolution improved...
Who supplies rear view cameras to auto manufacturers? There has to be a way to retrofit a better one into the tailgate handle...
The screen is not the problem. The resolution of the screen is very good.
Gringo
I hate to say this but the screen resolution will not be good, I already asked the engineer about it. Also even if you hook up a higher resolution camera, if the screen is not capable of handling that resolution then you wont have any video.
No different than cranking the resolution up on a monitor or TV, get outside of the rate it can handle and it will not show anything.
that engineer of yours fed you a line of bull.
the resolution of the screens is much better than the cameras. if it weren't, then why can video files be played that look decent on it?
from a 2013 press release of the 2014 mylink:
"One of the most noticeable additions to the new Silverado is the available high-resolution, full-color touch-screen display radio that is seamlessly integrated into the top of the central instrument panel. This vibrant LCD screen is standard on LTZ and available on LT, and it displays a home page resembling a smartphone screen or tablet, with just a few, large buttons and easily recognizable icons to execute commands."
  • 3 years later...
I would love to see the difference in quality of someone who swapped the factory radio for an aftermarket and retained the original backup cam.  Or added the optional 3rd brake lite camera.
I have a 2015 LTZ . would anyone know if there is a higher resolution camera for the newer trucks?
I have a Pioneer head unit with Maestro RR interface using factory back up camera and the picture is crap. Worse then the factory picture. Reason for this is the camera GM uses is crap.
Maybe someone can post a picture of the quality of a 2019 backup camera, or any other newer GM vehicle. Maybe you can make these fit, because as far as i looked, the camera works just with a 4-pin connection like any other backup camera.
Do you guys really back up that much?
My wife’s 19 camera is awesome but it’s 5 years newer than my 14 LTZ.  I’m only in reverse for 20 seconds at most so not a big deal to me.
I agree with the whole thread.  I have a Tahoe I put a pioneer screen (350) and a pioneer camera (100) in and the difference is outstanding.  Much better product than GM's
Firstly the screen can handle it, just play a properly formatted video using the media option and ou will see higher resolution.
Secondly the "bandwidth" should also not be an issue since this is traveling over a wire.
The biggest issue here would be drivers, and assuming that the open source OS software is used in all situations, the cameras would be selected for comparability so i doubt that would be an issue
Lastly, yes, some of us do back up that much especially when using the camera to hitch up. It would be nice to have a better resolution when hitching.
  • 4 months later...
Hi folks happy new years. I'd like to share to the thread that the 2019 Silverado LT camera that I have has very poor quality.  I have a loner Traverse and the quality is nearly HD like quality night or day. The Silverado camera is grainy and even flickers.
    tararebecca
    tararebecca
  • Who's Online   3 Members, 0 Anonymous, 656 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
