look good , need photos of light bar ??? Please
First thing I said in my post was, "I don't have the light bar installed yet". Don't even have it purchased yet but am looking to purchase a 20" single row for the front bumper.
I haven't purchased any light bars yet either, but the last ones I had on my 01 Tahoe, I got off eBay really cheap and they worked great with no issues. I had a 52" above the windshield, a 24" behind the grill and two 4" pods in the factory foglight locations. Searching online the other day, I came across this website that has some really really good deals. I haven't bought from them and in no way am I affiliated with them, just passing along what looks to be some good savings on LED lights. http://www.qualitylightbar.com/ I'm probably gonna order some pretty soon.
I've been skimming this thread and I didn't see any mention of the light bars on superbrightleds.com. I got a 21" for my old Jeep off there for $70. The wiring harness was $17, and I added a strobe/key fob transmitter for an extra $17. The light bar is about 4,000 lumens and has held up to some serious abuse being on the front end of the Jeep for over a year.
I chose to wire the bottom led off the parking lamp circuit. The top part comes on when the switch is rocked active.
Plate was off amazon. Find them all over the place right now on ebay, gm parts direct, rock auto had 2 in stock last week for 5 bucks more and :
https://www.amazon.com/ACDelco-23476237-Original-Equipment-Assembly/dp/B010GLVW90/ref=sr_1_1?s=automotive&ie=UTF8&qid=1486517945&sr=1-1&keywords=23476237
Ebay listings:
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.X23476237.TRS0&_nkw=23476237&_sacat=0
Overkill a question for you I have a 2015 Gmc has the wireing for the factory trailer. Brake behind glove box and the gave me a pig tail that plugs into it to wire to a after market trailer brake I was thinking of getting the plate you go do you know if I could wire it the the plug and use it just like a after market one with the factory look have you herd of anyone doing this or is there a topic in here if anyone doing that would you know
I have not seen anyone do that, but that's a great idea. I have not seen a thread, nor do I know of an attempt to make it work. I think most folks just get into a aftermarket controller and call it a day.
I talked to a GMC mechanic about doing this and was told that it wouldn't work because the stock one is integrated into the display. Ever notice when you are scrolling through the display that there is a blank page, that's where the settings for the brake controller would be displayed if your truck came equipped with the stock one. The day I brought my truck home I noticed the pigtail in the glove box and was all excited thinking I could do the same thing you were talking about but oh well.
Here's where I mounted my switches. 1da7752b081b8cae2b2b77187ba1916f.jpg36d22463877b7e393574137afd0c886a.jpg
  • Like 5
Anyone put a light bar on a 17 yet? I purchased the RC grille light bar kit and went to install it just to find out I have active grille shutters. I read somewhere that one member just removed the shutters but left the motor so it doesnt throw the check engine light. What are your thoughts on that option as well.
i bought one very similar. worked great at first. except now it doesnt work at all. this reminds me i need to contact them and see what they will do. i really dont want to have to re wire again
https://www.amazon.com/gp/product/B01B0OAE9Q/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Edited by kammi10
You have to play with the light and tilt it at just the right angle and that will take care of the light high pitch noise. Some foam from the box in between some fins also helped. The 1/2 tubing fixed the wind threw the door and stopped the rain from pouring in thru the door jam. Poor design by RC in my opinion . If it was up to me I wouldn't recommend them at all.
What type of tubing? Kind of looks like 1/2 clear hose.
Sent from my LG-H918 using Tapatalk
Has anyone tried this setup,
http://zroadz.com/index.php/product/top-of-front-bumper-led-light-mounts/
I really like the RC light bar being behind the grille so I am kind of torn on if I like it out in front or not. Also, has anyone had any experience with ZRoadz and their lights? Are the good lights or would it be best to buy the brackets alone and get a different brand light bar?
Adding the final touches... I ordered it from Steve www.sneveysoffroad.com20inch highlander trail series with the combo beam. The install wasnt as bad as i planned till wiring the relay and switch.. Finished product evynybev.jpgRemoving grill was a BITCH... Be prepared to cuss and drink like a fish. Step one.. Open hood. Pull tabs out that hold the plastic overlay. Than there is 4x 10mm screws. Take those out... Next go in the wheel well take 2x 7or 8mm screws out. (this holds the painted peice above your bumper on) pull edges off till it reaches headlights. Now.. Slide under the head first under the bumper.. Above license plate there is painted to match clips push them with a flat head and wrap end of painted peice...There is 4x more bolts on bottom of grill a9umy4u8.jpgbyve8uje.jpg6aqu6e3a.jpgNow i used a dremel to cut slots for the mounting arm hereapu8avut.jpgDrilled holes and mounted.. PerfectlyLET THERE BE LIGHT!! THE ehare5uj.jpgyqahudub.jpgHigh beams and fogs.. (did that to) any3upa2.jpgYou can compare that to just light bar. Heres all together su9u5ere.jpgNow the best part... I'm not drilling into a 40k trucks interior... Chevy made my dah here. I just pushed my toggled switch into here.. Holds Extremely tight.. Ran wires under panel under steering wheel out the hood popper. ydu7azub.jpg3ega8e9y.jpg
I know this is a really old thread, but how is that switch working for you after this time? Any lessons learned or wish I would have done that thoughts?
    B07
    B07
  • Who's Online   1 Member, 0 Anonymous, 729 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
