The painted front end parts were part of the Z71 package.
Where did you get the handles and mirror covers from?
The Tungsten color is hard to come by and are usually more expensive than most other colors. When he does have them they go fast!!
I just messaged him!! What did you end up paying? What did you do with the chrome pieces?
I paid $290.00 for the handles and mirror caps. They were in new condition when I got them. I still have the chrome pieces but will probably try to sell.
Lol... I am such a scab. Tungsten/iridium is the most common color of the guys company trucks I work with. One buddy just left me his keys one weekend and I "upgraded" his iridium SLE with chrome mirror caps and handles so my LTZ could get the paint matched stuff lol.
Sent from my SM-G900W8 using Tapatalk
Edited by 1994Vmax
Lol GOOD JOB!!
Anyone looking to trade color matched door handles and mirror caps for chrome?
where are you located I live on the east side of Houston
I'm located in Central Florida!! I'm willing to send and pay for shipping if you're willing to do the same? Large box will be under 20 bucks!!
Edited by drg6654
2015 4x4 crew cab 5.3l
Few upgrades include
Mcgaughy 9" lift SS kit with 1.5" rear add a leaf
24x12 maverick wheels with powder coated centers to match paint
37x13.50r24 fuel mud grappler tires
Complete regear from stock 3.08 to 4.88 with posi track duragrip
Extang 2.0 bed cover
Dual exhaust
T1000 Diablo tuner
Painted bushwacker pocket style fender flares
Tinted Windows
Custom blacked out grille
N-fab side steps
Tuscany hood
45,000 lbs Monster tow hook
54" led Cree light bar
Edited by Silverado0925
Dual exhaust
T1000 Diablo tuner
Tinted Windows
N-fab side steps
Tuscany hood
Wow!!!! Friggin wicked nice. With the lift and wheels alone there must be some serious dough in that. Someday......someday!!!l
Ya Jeff, you can say that lol .. I got in a little over my head.. With the custom paint and having to get new sensors I was in over 6k for rims/tires. It was my first purchase.. Not thinking or checking the gear ratio and having 37" tires I then looked into it and having 3.08 gears would get killed within 6 months if not burn the transmission up sooner so I regeared which was around 4K including the Diablo tuner.. With that being said if you count everything done I have just over 20k invested
Dual exhaust
T1000 Diablo tuner
Tinted Windows
N-fab side steps
Tuscany hood
Wow nice job... maybe lineX The steps
Beautiful Truck man
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
