Bed tie downs
Looking to get 4 new bed tie-down hooks, anyone find them for cheaper then the $62 the dealership offers. mine got ruined by the guys that did my line-x and I'm no longer in the area to have them replace them
That's the best price I've seen for the factory version. The dealers around here want $90 for a set of four.
I bought these but the price was still about $55 for four tie downs shipped. They come 2 to a pack and you get a 15% discount if you buy more than one set.
http://www.realtruck.com/bull-ring-bullet-retractable-tie-downs/?_rfkwc=1
Mike
I installed these on my 14', Dee-Zee-DZ97903, bought them from Amazon for around $15 a pair. Well made casting, easy to install once I removed the plastic cover over the access hole.
My oem tie downs don't seem to work with my pendaliner, let me try again tomorrow to see if they fit if not, you can have em for $40.00 shipped priority mail.
$62 is a great price for a set of the OEM hooks. The absolute cheapest I have seen them actually sell for is $45 from a seller on E-Bay a couple of weeks ago. He was the same seller with the LED bed light kits. Dealer list is $100, wholesale is $85.
Do those only work on a 14? My 11 could use those
Sent from my SCH-I535 using Tapatalk
The bed hooks are a direct fit for all 2007-2014 GM trucks. The inner bed walls are virtually identical on the GMT900's. I just bought a set of the GM upper bed hooks and they fit like a glove!
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
    • I'll bet your truck lost the bearings on a roller on 1 of the lifters, and now is wiping out a cam lobe.
