i bought my truck used and it came with the backflip vp. I know it is hard to see from this pic, but wanted to know if anyone has had this one for several years? How well does the vinyl cover hold up over time? is it going to fade out, dry up,crack and flap in the wind? it looks just like the regular backflip g2 from the underside from what i can tell.
i would just hate for it to start looking like a ragged out convertible top like you see on cars flopping around going down the highway.
maybe i'm way over thinking it...i do park it in the garage fyi
Justin%20Sonoma%20Red%20Metalic_zpsojlby
Yes, I've had the the Bakflip VP on my truck for 19 months. It is much like the G2, except it does have the vinyl cover attached to the top. I park in the garage as well...it has not cracked or faded, but I do keep it clean and conditioned with 303 Protectorant to keep it soft and plyable. The only issue I had was it was a little stiff in the winter when I folded if, but so was my Bakflip F1 on my older truck. Here is mine...
Edited by chuckl1218
I went to the local truck accessory shop today and had a good discussion with the owner. Apparently, Undercover is slowly buying the competition....Gator, Extang and Bak have all been bought out by Undercover.
Edited by ProPhoto
You're on the right track...
Every company you named, including UnderCover, is owned by a holding company called THI. You can find their web site at thicorp.com
Currently running the Access Vanish on my truck, like it a lot so far. No winter temps to deal with down here though, so I can't vouch for it in those conditions.
Edited by Hisdem
I put a tonno pro hard fold on my sierra this week in place of the undercover flex, I got sick of the flex leaking. I did prefer the look of the flex to some extent because of the low profile however, it wasn't worth the sacrifice of the leaks.
Edited by Imcrazy
snuglid sl
the carpet looks like crap in these pics. looks much better in person. 12v hard wired light. remote release. loving it so far.
Edited by smrr1
I'm still waiting to see the truxedo titanium... They said they have a few more new products coming out soon. If they keep taking forever, I'll get a deuce again.
This thing was announced TWO YEARS ago. They have installation videos and reviews, but no product? Given that THI owns both Bak and Truxedo (along with a bunch of others), the Titanium seems like it's nothing more than a re-branded Bak Roll-X. And believe me... I am SO done with Bak. Pretty leery of any of their other companies, too.
I know... They told me it was still in development.
I don't agree that it's a re-branded BAK based on the video's it operates just like a low pro in the latching system an the velcro on the sides. I bet it will be pricey though.I love the idea of the revolver and titanium but, BAK has such a bad reputation.
Truxedo lo pro qt. I like it. Does what I need.
Judging solely by looks this looks identical to my Access Vanish. If they are actually the same, it'd be interesting for those looking to check the price on both before purchasing.
Okay guys, I'm striking out on tonneau's for my '14. I tried the undercover flex for about 18 months but, it was not water resistant enough for my liking. I have now had two tonno pro hard fold's both work OK but, they can't seem to get the hinges right and the cover won't lay flat so I've got a huge hump on the side of the cover and the wind noise from the vinyl flapping against the aluminum chassis kinda sucks too so I am thinking of returning both the original and the replacement that Tonno Pro sent me.
My priorities are;
#1 mostly water resistant, if it sits in a down pour for 10 hours I can tolerate a few drops but, not a few cups of water.
#1.5 Must be some kind of 'hard cover' for security.
#2 Bed access, I either need to be able to roll or fold up the cover to get most of the bed open, like a roll-x or bakflip kind of cover or the cover needs to be easily removed like a tonno pro hard fold or extang solid fold.
#3 I don't want to spend more than $7-800ish if I can help it.
Here is a pic of the hinge miss-alignment on the tonnopro:
    Chris80s
    Chris80s
  • Who's Online   4 Members, 0 Anonymous, 879 Guests (See full list)
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
