If the drop-in plastic bedliner fits OVER the rails, it will interfere with most covers and so the drop-in will need to be cut. If the drop-in bedliner fits UNDER the rails, you're probably OK in most cases. In some cases, you may have to trim the drop-in so that the cover's clamps will fit properly. In both cases (under and over the rail bedliner), the bulkhead piece (area behind the rear window) should be cut off. It's not mandatory, but most covers will fit much better with the bulkhead piece trimmed off. If you don't cut it off and you have factory plastic rail caps, there will be a gap between the factory rail cap and the drop-in bulhead piece and that's where water will leak into the bed.
Of course, you could remove the plastic bedliner and throw it away instead of cutting it.
Edited by TruckDaddy
Here's too pictures of the bed cover. Its dark outside right now otherwise I'd go take one. The first was taken when I was looking it prior to purchase to show the scratches in the plastic on top of the tailgate, but you can see how high the liner comes up in the front of the bed. The second was from the dealer pictures.
Does the drop in liner fit under the rails? If so most of the folding covers should work, but routing the drain tubes on some may require drilling.
I have an Extang Solid Fold 2.0 that does not require additional side rails or a drain tube.
I was able to get it for $760 from an authorized dealer and it was shipped directly from Extang.
The drop-in liners fit under the SIDE RAILS (important distinction). The factory liner does not come up over the FRONT RAIL while some aftermarket liners do. Personally, I would opt for an aftermarket drop-in that comes up over the front rail (but is still considered an under-rail liner because that's relative to the side rails).
Question about Autoanything and coupon codes. I have a code for 20% off my first order with them. Today in my email I got another email that says they are having a flash sale with 20% off code. Do they let you use both codes to buy a cover? I see the Access Vanish and think it would be pretty sweet at 40% off.
Thoughts?
I chatted with Autoanything and was told exactly what I thought. Nope, only one code at a time.
Edited by Eddie 70
Thoughts?
They were going to let you use a 20% off on a tonneau cover? I tried to purchase a Undercover Flex on there today and the 20% off did not apply.
Does anybody know of any sites that will be having sales soon. I know Black Friday is coming and would like to purchase a tonneau cover soon.
Price match and 20% would be sweet for sure. 20% was going to be $310.
I bought the Access Vanish tonight from Autoanything price matched to 4wheel at $289. Pretty happy about that.
The 20% code that Autoanything give you does not work for a whole lot of products that they sell. Click restrictions link to see all the companies that you can not use the discount for.on the
I noticed this. I put the code in and none of the 3 things in my cart were discounted. I chatted with one of the reps and got around 20% by price matching on my order total.
The one thing I did when I just purchased a Tonneau cover was I started a chat session and told them that I thought that not being able to use the code on anything that I wanted was not right and they did and up giving me 10% off of the cover.
The leer looks good, very OEM look IMO. How's it do for keeping your bed dry?
I really like that Leer cover MiltonKid! Very nice. Maybe when my newly installed Access Vanish wears out a Lear like that may be on mine too.
    DM22
    DM22
  • Who's Online   7 Members, 0 Anonymous, 1,127 Guests (See full list)
