I have a BRAND NEW SET of STOCK running boards off my 14 Denali .....FOR SALE
Would like to see an pic please
Where are the stainless trim pieces I've seen on the Amp Power? I've only seen one user here with them.
Looks good!
Looks good!
They are an option I opted not to get them because it would bring more attention to the step and the small gap between the board and truck. I think it looks better without the stainless steel strip cause then the step is more hidden.
Hey guys, thuis may have been addressed (in this very thread) but I can't seem to locate it. We're up to 30 pages now so..
Anyway, I just put a set of 6" chrome steps on my crew, bought em off a guy who had them installed by the dealer. It came with 16 bolts, and 4 cage nut/clips.
The front 4 holes horizontal and vertical are threaded on each side, the back horizontals are not, nor is the verticals. You acn use the clips on the verticals, but there's nothing to use in the horizontals in the rear?? I have 4 bolts left over and I'm nervous about heavy passenger getting into the rear of my truck.
What do?
You need to get 4 more cage clips 4 for the verticals and 4 for the horizontals
Edited by never_rested_24-7
^+1 I never noticed the uneven gap til it was brought up on here, and now.... minor, but there.
has any body cut these boards down to fit rec.cab yet . I thought about buying a double cab set if they are adjustable and leaving them long to stick under the bed so I have a step back there
Not a bad idea. Only thing is you would have to open. The door everything you want to use the step in the bed
Edit: I'm not sure but I think they only make one size board and you have to cut it down. I could be wrong but that's what I am under the impression of for double cab vs crew cab.
Edited by Mike1220
opening the door would not bother me .I just like the thought of it being out of the way when I am driving ,
it looks like the mounts are adjustable but have not seen any in person .would like to look at a set firsthand
The control arm to board mounts are adjustable. Where mounts to the board is on a track that until the screws that hold the board to the arm are tightened. They can slide. Once the screws are tightened and the boards are on, they will not slide anymore.
thanks I would still like to see a set before I make a commitment on that kind of money
Yea they are quite expensive. Where are you located? If you are anywhere near me you can see mine. I think you have a very cool idea to make one into a bed step and a cab step.
I live in north east Oklahoma it is just a hop skip and a very long jump to you
Just chacked. Extended cab and crew cab are the same part number and therefore the same thing. If you order a 'extended cab version' you will get the exact same thing I got for my crew cab except you would have to cut it to fit an extended cab. After cutting the end piece should reinstall no problem to the newly cut end.
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 815 Guests (See full list)
