I found out what the steps on the reaper are. Southern comfort auto, maker of the reaper, messaged me saying they are Lund international Rock rails with steps
340 for the rails and 115 for 4 steps on realtruck. Not too bad. Good find. :thumbs:
We like the Raptor in stainless ... no peeling chrome or need to ever paint over chips ...
I have no idea what to replace mine with. I have the factory, but one is damaged. I have the chrome, but I dondon't know if i want to stay chrome or go black. I lile the wide steps like the factory, but I would like to get something unique. Opinion greatly welcomed.
Honestly, Amps are the best way to go. No need to worry about them getting damaged while driving since they tuck up under the truck. I love mine. No issues. Best thing I have put on the truck IMO and will probably always be the best thing I ever did.
The wide amp steps make it much easier to get in and out and they really do drop to the perfect distance from the truck to make it easy to get in
Get them and you won't regret it!
with the nfabs, do you guys find the steps are in a good spot? they seem like they are kinda far forward. (im probably completely wrong but just have to ask)
They kind of look like the hoops are a little forward but they're not. If you open the door they're in the right spot for the space in front of the seats. I used to have WEston 3" tube bars on my old truck and the N-fabs I have on my '14 are much sturdier and don't get dented. the horizontal bar that the hoops are welded to also seem to do a good job of protecting the rockers. They cost a little more but well worth it to me. Also as you can see I got the bed access bars which I also had on my old truck and that helps a lot when trying to get into my toolbox without having to climb in the bed (I'm only 5'9").
awesome thanks. ive got the stock chrome tubular ones, but im not really a fan of them, they were just on the truck when i picked it otherwise i wouldnt have gotten them.
hollow with no end caps, easy to fill with snow, dirt mud etc.. not the best design IMO
they're also useful when you park next to people... Especially the one that like to swing the door wide open without looking..
got mine off Ebay for $204 5" thick.Very well made and also come with limited lifetime warranty..
http://www.ebay.com/itm/350841932073?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_3645wt_1172
Do these mount to frame or rocker? And what is the difference? I've been told to get frame mounted running boards by a few people
No! I returned mine for that very reason....
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,321 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
