14 hours ago, zikronix said:
It's there I can vouch for it that's the part number I ordered. That diagram isn't showing it but it is there.
Sent from my Pixel 2 XL using Tapatalk
So, with my part numbers I do not need to order the armrest assembly or rear trim plates?
Does anyone have the part number for the 2018? I know there's a difference in the wireless charging lids between the 2017 and 2018. Would like to get the 2018 version. I spoke with GMPartsNow who gave me the part number 84288040, but I don't think this is right.
I don't think that module can be found in the complete consoles. Idk
I don't know because I'm unfamiliar with that part number I can only speak to the part numbers that I ordered and what I received
Didn't you say your's came with the wireless charging lid?
It did but it came with the older style single coil version 2 module not the updated 3 coil module which is in 2018 trucks.
None of the parts houses ive seen can filter 2018 parts. Its highly likely that you cant get 2018 complete console with the updated 2018 wireless charger
Edited by zikronix
3 hours ago, Scott Fish said:
I ordered yesterday morning and my order was cancel in the afternoon due to back order and no date.
that sucks!
I contacted GMPartsNow.com..
For any one wondering, this is what us included in part #84017260 center console in cocoa.
(all parts in blue)
well I ordered it today , we will see what I receive and what else I will need to order.
Johnny01: when you receive your order could you please let me know what came with the console.? I'm about ready to order one for my LT Z71 2016 CHEVY SILVERADO. THANKS.
Sent from my SM-G935V using Tapatalk
My order was canceled. They claim a backorder from gm with no eta I’m having a lot of trouble finding one. They claim one in Texas 210 681 4900. Part 84017262. They want 200 to ship it to me.
I finished my console swap last night fully. Only thing is wireless charging isn't working. Maybe it's my phone but I have no idea yet
You’ve got the new 2018 module? Or what came with the console?
No clue what the console.is even out of
    • Mobil up another dime this am , $3.89, others will probably go up later. Any ideas on the reason for the increase other than greed? I've been working 14 hour days and haven't caught the news in a few days.
    • AMSOIL SS is about prevention and it is very good at it's job. I've never seen it claim to be a cleaner however like Valvoline R&P. Almost any oil that has some Ester or Alkylated Naphthalene in sufficient quantity will do a good job at keeping the rings functional.     I see the market splint among these types in two groups; those that use the same tech in every weight grade and those that reserve the tech for the EPA (EPA) friendly grades. Mobil 1 for example keeps the Advanced Clean chemistry out of the SAE 40 and up weights. Other like HPL (top shelf group and No-VII), Red Line HP, TORCO, MPT30K use the tech in all grades. Just not something the Wally World oils are into.
    • Max Trailering Package.  RPO code NHT.   includes 3500 HD Frame, 3500 HD Leaf Springs, 12" Rear axle and 3500 HD Shock Package.   GVWR goes to 11,750lbs for crew cab standard box 4x4, 11,900lbs for crew cab long box 4x4.  2WD crew standard is 11,500lbs, 11,550lbs crew long 2wd, and 11,450lbs on regular and double cab 4x4.       There is also NHT on 1 ton dually regular cab 2WD.  includes 3500 HD Frame, 3500 HD Leaf Springs, (F60) Heavy Duty Front Spring/Camper Package, 12" Rear axle, 3500 HD Shock Package, and Z6A Gooseneck / 5th Wheel Prep provisions with bed stamped holes and caps.  GVWR of 14,000lbs.
    • https://www.msn.com/en-us/autos/general/what-makes-this-1963-ford-falcon-red-rocket-special/vi-AA2asoRz?ocid=winp2fptaskbarhover&cvid=be9c1b4f79ff4211c526abd60f6da012&ei=16
    • True. My statement needs qualification. "For a shade tree mechanic, re-assembling the front engine to achieve a rough baseline timing of 0 degrees, as is approximated and indicated by common visual indicator mark alignment, measured with a human eye capable of 20/20 vision *with correction, I am reasonably confident that I have followed the outlined procedures/ prescribed methods for verifying baseline timing."   😉   In the end, the computer sets the timing, it's continuously variable based on sensor input, and the distributor only has a degree or two of physical adjustability intended for dialing in the final setting for cam ****** once everything is back together. But even that final value is acceptable within, I believe, +/- 3 degrees.   I thought my exhaust project was going to be a bear. To my surprise, the old clamps came right off last night, and I was able to unbolt all the hangers instead of having to muscle the rubber mounts. The old cat is ready to slip off the factory y-pipe. The rest is ready to come out with one or two cuts, and I've got a fresh blade waiting. I love living where rust isn't a thing.
