All done, love it. Best upgrade so far.
How long did it take to deliver ?
About 6 days from order being placed to being delivered.
I ordered through GMPartsNow though.
I did gmpartsdirect. Friday is day 13 no update
What year is yours Mine is 2016 Black interior. What is the parts list.
Mines a 2018, ordered the 2018 console which is the exact same as the 2016 except it has the newer version of the wireless charger.
Here’s my parts list:
What were the cables for. I didn’t order any. It appeared in the diagram I received they were included
Routing the USB's from the HMI so everything works like stock. these are detailed in PGamboa's thread about this.
Johnny01: what was the shipping on it?
Sent from my SM-G935V using Tapatalk
Where did you order from?
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 827 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
