Does anyone know if the center console swap works with the 4x4 floor shift?
Unfortunately it will not work. The 4x4 floor shift will be in the the waybe0d937509a42e45956a74c8faa61122.jpg
yes it does work, i did it a year ago , i just didn’t put the handle back on , i posted pictures here somewhere
Just bought a 2018 gmc 1500 slt and cannot wait to do this mod!!!  I will try to read thru most of the thread before I start bugging everyone with questions...
Guys/Gals,
In an earlier post of this thread, I mentioned being on a back order status for Center Console Harnesses.  That is no longer the case!  I have been able to source the needed connector and have resumed production.  I will also be making these in advance (for 16-pin configurations) so that I can ship quickly upon order receipt.
I am also working with a specific GM Dealer/Store front that is working to put these consoles together as a complete "kit" so that you are not having to order 9 different part #s to make up the console.  We are also working on a potential discounted price for referrals that come from me.  So stay tuned for that.  The pricing will be competitive with what you see on the many GM Online Store fronts.  We are trying to streamline this process for everyone so that ordering will be as easy as possible.
Thanks everyone for the support thus far!
  • Thanks 1
Awesome!!  Let me know when I can place an order.
Send me a PM or email me at [email protected]
I’ll need to validate your truck.
Thanks!
Yes please let me know when I can place the order for the complete kit would love to do a console swap
On 10/10/2018 at 9:28 PM, pgamboa said:
Guys/Gals,
If my current jump seat doesn't have wireless charging, once buying this kit when it becomes available, would I be able to have that option?
Yes. All versions of my center console harness will have provisions for wireless charging.
Note: if you get a used console with wireless charging, that is not the latest 2018, you’ll have to swap the module out for it to charge newer phones.
Thanks Phil! Did you start getting pricing and availability info on these kits?
The dealer I’m working with is closed due to the Hurricane. I’ll know more in the days to come. I think it’s around $775... and I think that’s shipped.
Cool, that sounds like a fair price. When I’m ready for this I’ll reach out. My next mod is getting that Echomaster front camera bought and installed before the winter hits since the cold has already hit here in IL.
It’s crazy how we can turn these trucks from an LT trim to an almost 100% LTZ with kind helpful guys like yourself [emoji106]
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,412 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
