Theres our missing cable! holy hell!
Is the output on the hub a black connector though? Might need to be black to black?
Sent from my iPad using Tapatalk Pro
Maybe but looking at the pictures of the hub here
I would think that grey would fit in the hub. The keying looks the same
HMI Green to Grey (Front USB Hub) Part 19303284
HMI Black to Brown (Inner USB) Part 19303285
and this new cable output of front usb to glove USB Part 23225657
Alterntively would could use use generic Microusb male to USB A Female or a cable like osirus mentioned
https://www.amazon.com/gp/product/B015HKPDAE?pf_rd_p=d1f45e03-8b73-4c9a-9beb-4819111bef9a&pf_rd_r=HJVW9D9NJGNQETAPW9T4
33 minutes ago, Baldhills said:
youre right, and looking at the cable again the part where it exits the gray connector would put in the way of the other plug on the front hub. IDK I have an extenstion cable that im gonna screw with tonight but I also have the green grey on order (got it from jet.com for 20.00) so ill let you know more of what i find on thursday
Edited by zikronix
correction
On 9/8/2018 at 12:46 PM, Osirus said:
I bought a cheap mini USB female to USB female adapter on Amazon for testing. I disconnected my inner USB hub (the one that wasn't working) and used the adapter to connect a USB flash drive directly to the Output of the front hub. It worked.
https://www.amazon.com/gp/product/B00474R7HO/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
(This part wouldn't be used in the final setup, it was just used to verify that connecting a flash drive directly to the Output on the back of the Front console USB hub worked).
So both hubs are connected directly to the HMI. I verified this worked a few weeks ago, but it means the Glove Box port has nowhere to connect to, however with this testing I should be able to connect the Glove Box to the front Hub and have everything working. There isn't a specific part that I can see that would do this, but they're just Mini USB connectors so a generic cable should work, would just need electrical tape or something to keep the connections secure.
This means I should be able to run:
HMI -> Front Console Hub (Green to Grey cable)
HMI -> Inner Console Hub (Black to Brown cable)
Front Console Hub -> Glove Compartment Port (generic Mini USB extension cable) https://www.amazon.com/gp/product/B015HKPDAE?pf_rd_p=d1f45e03-8b73-4c9a-9beb-4819111bef9a&pf_rd_r=HJVW9D9NJGNQETAPW9T4
I just did this. Aux didnt work
Edit: I messed with this and I thought i had a different wiring than what you listed here, but now looking at what I wrote below its the same and it is working can confirm. I also found this cable.
 https://www.amazon.com/ACDelco-42465826-Original-Equipment-Cable/dp/B01K8C5Q8K/
Edited by zikronix
Looks the same, just doesn’t have the 90 degree bend on connector at glove box. Not sure if it’s needed.  Depends on how much room is behind glove box.
7 hours ago, Osirus said:
Is that female end the same connector that the glove box port uses?
Still criminal pricing, though. :(
yea its nonsense...ill stick with the extension cable. im still not convinced this is the actual part number. Im gonna investigate further
3 hours ago, Baldhills said:
Hmm. That looks promising. Cheaper too.
HOLY SHIT look what I found!  Its a short version, which makes me wonder about this entire wiring thing.
https://www.amazon.com/ACDelco-22885186-Original-Equipment-Cable/dp/B00B4L2QRY
16.00!!!!
Edited by zikronix
Most of my time (when I’m not building harnesses) is spent fishing for the right cable, harness, connector or pins. Just today, I spent almost 3 hours looking for a couple of connectors. I must have looked 15+ schematics on connectors, keying, options and comparing with USCAR connector specifications. It is really painful.
  • Like 3
15 hours ago, Baldhills said:
Too short to run from the front dual hub to the glove box though.
That's what I thought when I saw it, too.
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
