Rattle
Has anyone noticed a rattle coming from the back seat area? I have a crew cab and haven't been able to find the issue yet. I doesn't happen often....just when I hit a big bump. Curious of others have experienced the same and what the fix was.
Check all the bolts that attach the rear seats to the floor. Make sure they're all really tight. If not, the seat will flex ever so slightly causing a rattle noise.
There are several topics on interior/rear seat noises with other theories/suggestions/fixes. Try running a Search.
Those having back seat rattles..
seriously..
open back left door.
fold seat up. SLAM that thing down hard as you can..5x.
noise will be gone.
Swear to god. It drove me bat shit insane. tried it..PERFECT.. theres a small tab in the process of making the hinges and some times the metal wasnt cut perfectly. slamming...well fixed it :D loaner vehicle also lol when dealer gave me one while mine was being diagnosed for vibrations
Check the jack stored under back seat. I have a rattle coming from back there also. Didn't matter if seat was up or down. When I got home I got to checking and if I grabbed the knob on the jack hold down and shock it I could make it rattle. The knob was tight but something to do with that jack seemed to be my rattle. I'm going to check it out better when I get a chance.
seriously..
noise will be gone.
No kidding...I tried this on the loaner I got today because it had the same rattle as my truck and IT WORKED.
I got one that sounds deep in the dash center. Only happens at certain speeds it seems. So I guess its related to the tire imbalance or whatever.
Haven't heard anything from the back so far. I guess I've got a little less than 9000 on it.
seriously..
noise will be gone.
LMAO! So just lose your s**t and smash the seat and you will fix it.. Thats like something I would do lol.
seriously..
noise will be gone.
I swear... It works
Sent from my HTC6500LVW using Tapatalk
I swear... It works Sent from my HTC6500LVW using Tapatalk
I had to see it to believe it :cheers:
