Obviously not all done today, but since the end of January when I got the truck. White Diamond crew cab LT. Had the dealer install the 6" oem chrome running boards. Since then I installed oem color match mud guards, oem led bed lights, Weathertech in channel rain guards,Weathertech front and rear floor mats, Bakflip G2 tonneau cover, BedRug, VLed 5000K fog, cargo, and reverse bulbs and last night I put in the Pop&Lock tailgate lock.
I have the VLed 5000k led h11 bulbs in the garage to install. I had them in once but had issues with them randomly flickering. I have the Morimoto hd wiring harness and error canceler now and they work fine. I haven't permanently installed them because the Morimoto harness is only long enough to mount everything on the passenger side where room is limited. My plan is to extend the harness so it is long enough to mount all the components on the driver side where there is plenty of room to work and make everything nice and neat.
Still considering a level/lift on the front, front tint and maybe a bug deflector before the hood gets chips.
Pop And Lock done today. Fantastic! Would have gladly paid Chevy the $100 they could have charged me for it, IF IT WAS ONLY AN OPTION!!! :idiot:
Finally got the Line-X done today and installed my Roll-X cover .
any issues with line x application?
Line X went great , made sure they did not go over bed lights out the holes for any hooks . Looks really good .
Sent from my SCH-I545 using Tapatalk
I installed the chrome door and tailgate handles, and chrome mirrors to my '14 All Star Edition. They look great!
I installed 9011 65w headlights last night. I put retractable tiedown hooks in all 9 positions a week or so ago.
Did they tape off the holes on the bed walls when the applied the Line X?
Did they tape off the holes on the bed walls when the applied the Line X?[/quote
Yep, made sure of that as well as not putting the line x sticker on my rear window .
How bright are the h11's compared to the factory light output
What did this cost you and how hard was the install if you don't mind me asking.
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 686 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
