Post pics of the halos and a video for YouTube lol
Sent from my SM-N900T using Tapatalk
Finally installed my 55W 5000K HIDs today. The color PERFECTLY matched my LED DRLs and made a HUGE difference with sight. Extremely happy. Now to retrofit the fog lights with projectors and soon after another set of HIDs will be in there.
that's sexy, I want some one my silverado.
Installed the Led tail lighs today.. :)
Hey Block, where did you get those tail lights?
I know I am a little late on this one but being in the wrap business, they did a GREAT job on that!
If that vinyl fails or gets too hacked up there are other options to replace it if you want to keep the look.
You need to use vinyl that is made to adhere to “Low Energy” surface….. Plastics, they use this for graphics on things like ATV’s and snowmobiles, motocross bikes, and then laminate with heavy duty laminate to protect it from chipping and fading.
They can be found on eBay.
SWEET!… did you buy those or paint the factory one’s?
Thanks!! They're covers. I got them HERE. I took my truck to the dealer for a transmission cooler line connection recall this morning and the guys at the dealer went crazy!! They just couldn't get enough of them. Kept saying they looked like the colored Corvette Brembo calipers. I'd never seen covers before but thought what the hell, I'll try 'em and I'm glad I did. Nice quality and simple to install.
Thanks!
What brand? Where u get them?
I removed the bed emblem for a cleaner look....
DDMtuning.com. They are from China but many other users on here with Sierras have used either DDM or Theretrofitsource.com (TRS.com sells Morimoto kits which are pricey)
I got the DDM kit, they are nice but still cost effective. Some people have needed both the wire harness and the error code eliminator. But apparently my truck didn't like the error code eliminators and so my truck decided to short them out and ruin them, so I wired everything without the ECEs and it works fine. Go check out the HID topic moto created and you can see more Info about all things HID and what you'll need.
http://www.gm-trucks.com/forums/index.php?/topic/152762-HID-Headlight-Bulbs---HID-Projector-Retrofit
Running boards are off , much cleaner look imo .
Sent from my SCH-I545 using Tapatalk
Got those pesky radio knobs fixed! Lol.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
