Finally installed the front end of my Mcgaughy lift, hopefully will finish up the back tomorrow.
Good god , this will look awesome
Got to finally using the bedliner for its intended purpose.....the bed lol
82E39C20-41F8-4E73-B30E-29F39DF73BEF_zps
F15211BC-63D0-440E-A500-37312FAD6701_zps
So you bed lined the grille and headlight trim, before you bed lined the bed of the truck? Lol Edited by Mike1220
Yes lol Im crazy i guess lol kinda how it happened with my xterra. first i did the plastic trim and bumpers, then the headliner, and then the whole outside lol
Finished installing the lift and it rides pretty good so far
  • Like 6
Updated pics of my truck.....
E293C5C4-3766-4800-960B-81068A7AF099_zps
16BBE26F-0CE8-4BB6-94C1-8A358B04CF36_zps
ACEE6369-DA73-428D-AFD7-4E665E396130_zps
30EE91B7-E909-4D24-AD0C-C91343225C0B_zps
Looks good[emoji106] I think you should do the bumpers the same as the grille, and maybe even colormatched the fog surrounds, and then your done[emoji20]
Im gonna bedline the bumpers for sure now cause well my addiction has started back again haha but I think ima do the fog light surrounds black but the tow hook tan thing on the front color matched. Eventually the whole thing will be bedlined silver cause bedliner is just awesome. Here is my old Xterra color matched bedliner molten lava metallic
ED9CD6DE-0038-4A69-BCEF-2230E8AA2251_zps
Dear lord... what have you done!?
I know some people don't like it but I use my 4x4s so not scratches. no rust holes and it being tough as nails is so worth it. plus not having to wax and buff was just plain amazing.
Did you trade that Xterra in? Just wondering what the dealership said and how much they deducted for that.
No I didn't trade it in but when I pulled up to the dealership everyone was out there and when they found out it was mine they were trying to get it off my hands but at the time I wasn't selling it. Heck even when I took it in to the dealership for maintenance everytime they called me they wanted to buy it off me. Even the owner of the dealership called me for it but I turned him down too. I never asked them what they wanted to pay. Probably should of asked lol but I was so in love with my xterra at the time. I don't think they would deduct for it. Heck you can buy a brand new silverado painted in Line-x from the dealer
Edited by stevencox93
I guess it has its perks, but did fuel eco drop enough that you can see without all the liner? How easy is it to get bugs off the front??
I'm really curious to see how the bed lined truck turns out. If it looks like your Xterra or looks as good as the grille does, then it'll look damn good [emoji106]
It won't affect the fuel economy. Its not heavy enough to. Like a car painted 4 times doesn't get less mugs than a car with 1 paint job. Also cleaning is easy. I cleaned the bugs off by just shooting the grille with a water hose
Im confident it'll turn out great. I used a different PSI on the truck than I did the Xterra and I like this new texture I got so I'll be doing that and I'm just unsure since it'll be silver bedliner lol but it'll be a year before I do it
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,260 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
