Line-X? Looks good and should take some abuse.
No did it myself with Raptor Liner. Sprayed my whole Xterra with it years ago and love the stuff
Been a while since I've posted. Haven't done much to the truck, but today I did get her tuned & messed around with some cans of plasti dip. (2 things were edited, let's see who could spot them).
Nice truck. Love the lights and color did you color match handles and mirros cap?
I had the bed done when I bought the truck last year. I scrubbed the backend down last weekend and the Line-X looks new again...
Thank you, I'm in the process of colormatching the handles and caps. I already did the bumpers, door trim, and one of the handles, just need to finish the rest.
Sorry buddy, been really busy at work. I was going to do a build for my truck last weekend, but didnt get to it.
Here are some pictures of the module that was installed to have the ability to take over the factory display with 2 RCA component inputs. Gonna pick up an HDMI to composite device so I can hook up my Miracast dongle and have the ability to mirror my phone to the dash!!
more info and where did you get the module from would be greatly appreciated! Thanks
so they may have been done over the last few days!!
i got the factory 2015 splash guards....
stampede no drill no clip front hood guard
and a line-x bed liner!!!
i love the look with the stampede hood guard and super nice quality part!
next is corsa exhaust in the works!
also forgot 25% tint on front two windows!
Did you color match the fender flares? If so, please share the details...
Yes sir, just used some white plasti dip and some pearlizer. 5 coats each.
I think it looks good. Did you take them off to do them, or mask and paint on the truck? I've thought about doing the same on mine. It will be interesting to see how durable it is sine they are prone to road debris.
Added these bad boys to cover up the airbag warning stickers on the sun visor. Picture isnt the best but it looks amazing in persone438b21c79f4935cc22bc1a6c88a8f7c.jpg
Also wrapped the bowties
I took them off, very easy. The little "wind/mud" flap on the rear was a bit of pain to put back on properly but nothing too extreme, just an inconvenience. After driving hundreds of miles with them on I've noticed the inner part gets the dirtiest obviously and it's tough to clean (I have a white truck though) but they've held up well. One has a very tiny chip but that's after hundreds of miles in different terrains (gravel, dirt, pavement).
Finally installed the front end of my Mcgaughy lift, hopefully will finish up the back tomorrow.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
