I switched out the white center high mount lights to LED. Is the only way to have them come on is with the button on the inside of the truck? I was hoping the light would come on when unlocking the truck.
That can be done with the cargo on in reverse mod.....they will also come on while driving in reverse [emoji106]
Also helps if u need light in the back of the truck and didn't hit the switch first
Edited by mkeddie
I really like the look of that. Where'd you get it?
I can probably make those too!! I have a plotter and some vinyl!
I just like to point out, if you dont want glare backing up, you can always use the puddle light signal instead of the back up signal!
Do the diode trick to make them come on with reverse lights. Once you do that, they'll come on when you unlock with your fob.
Washed, clay bared, and waxed. Also ordered the driver's assist handle from my dealer.
Now, making a list of what to-do... So far: Fender flares painted to match, tonneau cover, n-fab steps, Corsa sport w/ headers, 4.5" Zone lift, and a tire that won't look too small! Something from 33-35s.
I have the Zone 4.5" lift and i run 295/60/20s. a pic will be in my sig... maybe that'll help. if i remember right the measurements on the tires are 33.9 x 11.8
Edited by sawyer_dowell_3
Thanks for the info! I'll research the diode trick.
Sent from my iPhone 6+
There's a big thread on here about it. I think it's called "cargo lights on with reverse" or something like that. It's easy.
I'm thinking about getting the underseat storage for the back seat of my truck, a Double Cab. Can anybody tell me if a gas can that's roughly 10x7 1/2x11 without the nozzle fit on one side? If not I'll just buy a smaller gas can for emergencies. The one I have seems to fit under the seat just fine, I just want to make sure it would fit in the storage.
You could rig something up and stick it in the spare battery spot under the hood maybe?
-Skeet
-Skeet
I just ended up buying a slightly smaller can that fit under there in the storage. The one I had was too big. Plus the one I did have the nozzle was a design where you can't store the nozzle in the can when not in use and that would have been sticking out towards the engine if I did what you suggest. And I wouldn't keep the nozzle off without some kind of cap to keep debris from collecting in the can.
Did you mount a switch in the cab and did the light come with wiring and a switch?
-Skeet
I installed the light bar with this : http://www.amazon.com/gp/product/B00MOQ3KIM/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Happy with it, was going to program it to the Homelink, but I think I would have to program one button for ON, and another for OFF, so for now I'm ok with the wireless remote.
If one button on the remote controls both on and off, then you'll only need to use 1 home link button [emoji106]
Also you can program another home link to control the strobe patterns if you have a free button and if your harness has strobe patterns. I did it Incase I ever have to use my spare set of keys since I keep the fob on my key ring
Edited by Mike1220
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
