Interested to see how this turns out as speaker upgrades are on my list of to-dos. Are you just replacing stock or doing amp(s)/dsp/subs also?
Didn't get a chance to do the install over the weekend. going to hopefully squeeze it in during the evening this week. I have the kicker setup installed with the additional dsp for the door speakers. I am hoping to just install the speakers in the door and dash for improved sound. I have a decibel meter i will be using to determine loudness before and after the speaker swap.
So it's a video of you videoing a video of your truck that you videoed. [emoji15]
But as for the head unit mod, very nice [emoji106] looks clean
It's essentially truck inception!
Haven't torn into it yet. I've sourced a set of Hyluxtek ballasts in town here so I'm gonna run those, as well I'll change out the relays and reground the wiring harness.
I'm chocking it up to bad luck with the Morimotos
Bad luck of the draw I guess, but the setup will be excellent when done. Gives me plenty of ideas. [emoji1]
Please for the love of everything that is holy install those bezels soon. They look so sweet! :thumbs:
I plastidipped my factory 18's charcoal grey, but they're not on the truck yet. I think I'll aslo dip the bowties to match.
Here is is, I did end up doing the bowties and I'm glad I did. The blue really brings out the bluish in the grey but overall I think it looks sweet.
My brother calls them douchebag rims :dunno: but drives an 03 Corolla with the spoiler and two corner trims torn off, soo... :thumbs:
Edited by jonny24
That truck looks so tiny.......no offense
Short bed????
Edited by mkeddie
10159ecf0fdba9e246c319eba06bc1c6.jpgadded the k&n filter and we'll I haven't driven it much but I really didn't notice a difference
I did the same no noticeable difference
Short bed????
None taken! I've always been a two door, short box kind of guy. It's the 6'-6" bed, what they call "standard".
Edited by jonny24
I think the rake is really pronounced at this configuration, does it bother you?
Yes actually, it's been on my list but I'm pretty cautious of doing anything to the suspension. I'm thinking about drop shackles on the back as it seems fairly noninvasive, but then I keep reading about vibrations and driveline angles.
Edited by jonny24
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
